Question about Friedrich M18DCE Air Conditioner
What model number? New filter?
I live in an apartment in a house, and there is an old through-the-wall air conditioner.  The plastic casing on the inside (front) of the AC says "Friedrich" while the metal casing outside the house says "Fedders."  I believe that the outside casing may be just that, and not a part of the AC itself.  In any event, I've just removed the front cover to find the most disgustingly dirty filter that I have ever soon.  Who knows when this was last changed.  (This is my first summer in the apartment.) This filter has no frame around it; it is just a "blanket" of what may be fiberglass fibers, covered in soot.  I measured it to be approximately 12 x 15, but it's hard to tell because it is mis-shapen and may have stretched, since there is no border or frame.  I do not know where to find the model number of this unit or how to find the correct replacement filter.  Any ideas?
  • 143 Answers
You can find "cut to fit" filter material at The Home Depot. One kind is called, "hogs hair". (It isn't really hog hair.) You cut it with scissors so it does not matter if you have a model number.
Posted on Jul 25, 2008
Where is the condensate line on a Frigidaire wall air conditioner?
There is sometimes a plastic hose between the evaporator and condenser side on the bottom of the case. Other models simply have holes in the metal for condensate to drain into the condenser side . Make sure there is no obstruction to the hose or holes. If you find none, then check the level of the unit. It MUST be slanted so the back of the unit is lower than the front.
Sep 19, 2015 | Frigidaire Heating & Cooling
I have a Freidrichs Kstar wall ac. It's about 15 years old. Need a filter for it and I don't have the model number. Any suggestions?
If I recall correctly, your model uses a foam type, washable filter. If that's the case, you can pickup one at just about any hardware store or home center. These are the ones that you can cut to fit, if necessary.
Hope this helped you. Please let me know. Thanks.
Jun 01, 2011 | Friedrich KStar KQ06J10 Air Conditioner
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
I have a 5-6yr old Maytag 11kBTU thru-wall AC unit
It should have screws on either side of the plastic part. Take those off and it will take some work to remove it. I cannot find my manual.
May 24, 2010 | Maytag M7Y10F2A Air Conditioner
I have a central air conditioning unit in the apartment where I live. It is a split unit - somewhere outside is my outdoor unit (and everybody elses too). Anyway I seem to get way too much humidity in my...
the humidity problem is from the condesation drain. It is more than likely to be clogged up keeping water in the condensation pan causing the humidity problem. This can be cured by a wet vac put onto the outside drain for the inside condensation pan and turned on. this removes the algae that builds up in the a/c condensation pans. Also, an a/c unit is designed to last 25 to 30 years depending on the location of the outside unit. Inside unit being an apartment, has other issues, it just may need to have some preventive maintenance done such as coil cleaned filter changed, motor oiled, etc....
Jul 08, 2009 | Carrier 38CKC030 Air Conditioner
How to change air filters on 2007 Mercedes C230 Sport
I have '05, both should be similar:
1.Cabin air filter is located above battery on right side against firewall.
Release three latches, remove filter housing, slide old filter out (housing is flexible), insert new
one, reinstall housing.
2.Engine air filter is on the left side of the block (follow intake hose). Cover is retained with six screws
(six point star shape,I belive called Torox, bit/scredriver size 25). Loosen screws (don' t pull all the
way out of the cover) lift cover , and remove old filter. Insert new one, reinstall cover. DO NOT
OVERTORQUE SCREWS! Screw holes in plastic filter housing strip very easily.
Note: Intake hose is very flimsy, one on my car came apart and had to be replaced.
Mar 25, 2009 | 2007 Mercedes-Benz C230 Sedan
I am living in a home with a carrier furnace. The furnace is in the back part of the house in a store room. It has two- 2 1/2 inch plastic pipes. One that suppplies air to the furnace and the other is...
As long as the fresh air intake pipe to the furnace is not plugged up the second vent is not needed some homes when they are new are air tight and need a fresh air circulation system
Oct 30, 2008 | Carrier Heating & Cooling
Need new filter
I went into Emerson air conditioner parts and they listed all the different filters and I was lucky enough to find the right filter , so I ordered it.
Jul 30, 2008 | Emerson Quiet Kool 10GV13 Air Conditioner
Filter size
Thats an A/C, what is the indoor unit model #? Does it have a filter box? If so what size? If not do how does your filters sit in the unit?
Jun 23, 2008 | Weather King 12AJA4801AH Air Conditioner
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Friedrich M18DCE Air Conditioner Logo
82 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
