Question about Microwave Ovens
Kenmore Microwave Oven cooktop light
The cooktop light is stuck on high. When touching the switch on control it will toggle from off to high to night and the relays click but light stays on. You say in the article I read that means a bad controller, do you mean the logic board or the actual touch pad? How long of a wait is it for you to repair controller for 39.95?
  • padysol Dec 05, 2008
    Cooktop light is on on all the time -- can't turn it off... Won't toggle between off to low to high at all.
    Have unscrewed bulbs for now, waitng for fix...
  • Microwave Ovens Master
  • 9,098 Answers
Turnaround is usually about a week "door to door".
The problem is on the circuit board, but we ask that you send the control panel assembly, by which we mean the plastic control panel frame, keypad, and circuit board as an assembly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 23, 2008
TYPE BULB FOR PANASONIC NNP295 COOKTOP LIGHT
Halogen Cooktop/Night Light Replacement
Be careful as the Cooktop Light Cover and the bulb may be
hot.
1. Unplug microwave oven or disconnect power.
2. Loosen the screw to open the Cooktop Light Cover.
(Be careful not to lose the screw.)
3. Replace the old bulb with a new one.
(use Max. 125 V, 30 W, Wide Pin Capsule Type/GY8.0~9.0
recommended)
do not touch a new Halogen bulb with bare hands.
Fingerprints may result in shorter life. Remove fingerprints
with alcohol.
If this bulb is not available locally, contact your local
Panasonic dealer. Part number is F612E6Z00AP.
4. Reinstall the Cooktop Light Cover with a screw
Dec 02, 2014 | Panasonic Microwave Ovens
Vent fan will not turn on.Display keeps showing vent fan off
Did this occur after a failure of your cooktop lights?
Or is there is buzzing noise present when the oven is not operating, or when the door is opened?
If so, then the problem is on the control panel, which can be repaired economically.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
Microwave Cooktop / Night Light not working
I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
Mar 06, 2012 | GE Microwave Ovens
I replaced the outside/night lights on my Kenmore microwave and the lights stay on. They are 3 settings, high, night and off and they do not cycle through, they are always on and won't shut off
This is a shorted relay on the control circuit board, which we normally repair for $39.95 nationwide.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 17, 2011 | Kenmore 63792 Microwave Oven
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
Sep 08, 2010 | Kenmore 80599 Microwave Oven
The exterior light stays on the low setting and will not turn off or toggle to the high setting. It's a Panasonic Prestige Inverter Over the Range Microwave(2007).
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
May 23, 2010 | Panasonic Microwave Ovens
I have a Kenmore Microwave hood combo model number 72180592402. The cooktop light stopped working. I ordered the correct light (6912W3Q001A) from sears and installed them. The cooktop light still does not...
May 13, 2010 | Kenmore 80599 Microwave Oven
My 3 1/2 year old ge spacemaker over the oven microwave with vent fan has stopped rotating inside.
Did the cooktop lights recently fail?
If so, then the problem is probably on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Cooktop light - night light only
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
95 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
