Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Unit-hand tool switch
Is there a diagram showing how to take the unit apart to fix the switch that controls the vacume source, hand tools or unit. I believe the switch on my unit is broken and needs replaced. Then, where do I get the part that is broken?
  • 1,673 Answers
Maybe this picture will help, most vacuum repair shops should be able to get the part you need. You can also try
Posted on Jul 23, 2008
How do I use the crevice attachment
Hi there! The crevice tool can only be used when using the unit has a hand vac. Remove the handle and nozzle from unit. Attach the crevice tool by inserting into hand vac nozzle opening. To remove, gently pull apart. Hope this helps!
Sep 30, 2014 | Dirt Devil SD20000RED Versa Power AllinOne...
How to attach crevice tool
Hi! Below is step-by-step instructions for attaching your crevice tool.
1. Place unit in an upright position. Push release button forward, then pull handle from unit.
2. Remove floor tool from nozzle.
3. Attach crevice tool by inserting into nozzle. To remove gently pull apart.
Hope this helps out!
Apr 26, 2014 | Dirt Devil Simpli-Stik 3-in-1 Bagless...
Won't turn on
probably a hex or star tool probably cost you more for the tools then the unit is worth.pretty much anything euro-pro is a thow away and is not designed to be fixed.
Jan 25, 2014 | Euro-Pro EP923 Canister Steam Vacuum
I have a Hoover SteamVac F5914-900 SpinScrub... The last time I used the hand tool attachment, it worked fine. Just tried to use it again, and now I only drips of water will come out of the hand sprayer,...
The brushes can be turned off on most of them via a switch on the hood. There shouldn't be water coming out onto the floor unless you are pulling the trigger at that top. You probably broke this when attempting to use the tools.
Sep 23, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Bissell Proheat upright dirt lifter 12amp
on the vacuum there is a switch one for the hand held attatchment and one for the floor you have to switch from hand held to floor
Sep 24, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
98 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
