Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis shut down during rinse cycle.
Maytag Atlantis washer shut down during the rinse cycle last night. I noticed an unusual smell (possibly burning) and it would not restart. Eventually did get it started again in the spin cycle. I probably had it overloaded. Any idea what I may have broken and how to get it fixed? Thanks.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Posted on Jul 25, 2008
Washer has been making an unusual amount of noise / burning smell
remove the door and screws on opposite side and the front comes off. Then the top will flip up.
Eric
Nov 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag washer has no spinning mode while in rinsing cycle. I checked the voltage-it's about 118 to 130 volt consistantly. Please advise.
Our Maytag Atlantis strted having some unusual operation problems and failure to produce clean clothes about 3 - 4 yeras after purchase. The transmission was replaced, no parts costs, reasonable service call labor costs. Has worked good ever since, another 3 years or so.
Call Maytag and they will discuss with you.
Jun 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Grinding sound from washer
the pully is the drain pump they can go bad or may have somthing in it, pump is not bad to replace part us usually 40 -60$ , you could burn belt up and be forced to replace it also, but if you replace pump would not be a bad idea anyway belts are 20-30 $
Mar 30, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
359 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
