Question about SMC Barricade 7008ABR Router
Blinking router Hi oszkar, I've already wrote to the page, but i'm not sure, whether you got any reminder or not, so i send you directly. Could you solve the blinking SMC7008ABR router problem? I hope you could, please answer as soon as possible! Thanks, kegabor
2 Suggested Answers
  • 13 Answers
SOURCE: blinking router
Here is the manual:
Is the unit working?
Which lights are blinking?
Posted on Jan 03, 2008
I just noticed on my 1991 softtail springer classic that when i cut either blinker on when i staighten up the blinker still blinks? i thought when u striaghtened up it was supposed to quit blinking!
Your bike does have a reed switch built into the speedo but to change it I think you have to buy a new speedo. Not sure about that. I have a complete turn signal troubleshooting guide that I can send you but you'll have to contact me directly. This forum will not allow me to send anything much larger than a thumbnail picure (150Kb). Send me an e-mail to , remind me of what you need and I'll send it to you. No problem.
Good Luck
Aug 27, 2010 | 2000 Harley Davidson FLSTC Heritage...
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
The modem itself is working fine with internet and stuff if its connected to the computer directly. but when it tries to connect to router the router's modem led is orange and keep on blinking any help?
Hi Friend,
Please follow the below steps
Step 1: At the backside of your router,press the Reset button for 20 secs and leave it alone for 20 secs.
Step 2: Then connect all the cables to the router
Step 3: And then configure the router by following the Link below,
Step 4: After Configuring the router,please check whether all the lights are glowing in the Router
Step 5: Now checked whether you are able to access the Internet using the Router
Jun 09, 2010 | Belkin F5D8236-4 Router
Linksys has stopped working - no connectivity. I directly connected the modem to computer and it works fine. Power light on Linksys is green but is blinking and does not go to steady green.
You can try to follow the steps from this link to fix the blinking power light of your router, because a blinking power light is a sign of something is bad on the router. But if after doing the steps and still a blinking power the router is already bad and needs replacement.
May 06, 2010 | Linksys Wireless-N WRT150N Router
Cannot connect to internet. router modem and globe lights blinking amber.
If the modem light is blinking it means that there is activity, so this is normal.
However, the globe/internet light needs to be solid green. If it is blinking it means it is attempting to connect to the internet.
Make sure first that the internet connection is working when directly connected to the modem. If yes, then the router might not be configured properly. To check the configuration on the router, access the setup page by using a web browser. Type in the address bar.
By default the password should be left empty.
Once in the setup page of the router, go to Internet WAN. Select the connection that your ISP is using. Either, PPPOE (requires a username and password from ISP) or Dynamic, (the settings are obtained automatically from the ISP). If you are not sure, contact your ISP.
I hope this helps!
Mar 01, 2010 | Belkin (F5D5231-4) Router
My wlan light keep going on and off on my wrt54g
Also check if the power light on your router is blinking. If it is blinking, that's an indication of hardware failure. To revive it, do a hard reset. Press and hold the power button of the router for 30 seconds then unplug the power. Wait for 30 seconds again before you plug it back in.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Bridge RCA Thomson DCM315R
Usually cable providers provide public ip directly to your company ( already bridged ). so no need to configure your modem to bridge.
- Connect the computer directly to the modem and if possible, let me know the ip address of your PC, So we can find the modem already bridged.
- If its already bridged, then Open the ports on your Router ( port number : 3389 for TCP ) or else you may try DMZ Host on your router to check whether it works.
DMZ ( Demilitarize Zone ) host which opens all ports on your network and shows ur computer to the outside Network which is not really secured one. but you can try it for testing purpose whether it let you to use remote desktop.
Hope this will help you
Sep 19, 2007 | RCA Cable Modem DCM315R (11603540)
A new router, recognizes the printer (HP Photosmart) and still won?t print from a distant location on the network.
I?m not sure about this one, but I think you should make sure there?s permission to access (share) the printer in the router and/or printer settings. If the printer is connected directly to the router, check if it?s in the right port and you?re not sending a print request to a different port. If that doesn?t help try to set it to another port in the router.
Feb 22, 2006 | ASUS WL-500B Wireless Router
SMC Barricade 7008ABR Router Logo
73 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
