Question about Toshiba 55H70 55" Rear Projection Television
Overscan My TV has overscan on ps3 games... its bearable on some, but on some games the HUD is cut off making the game almost unplayable does anyone have a solution to make the tv stop overscan?
  • tollfree90 Jul 23, 2008
    its actually all edges of the screen are cut off by a couple of centimetres.
    i can't recall there being a screen size option...
    there is a 1080i picture on/off, which i have on
    EXTREMELY sorry, my tv is the 55HX70
    forgot the X...
    I apologize again
  • 45 Answers
Do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Posted on Jul 23, 2008
  • shane white Jul 23, 2008
    right,sounds like you have the zoom facility on. i have it on mine but dont know how to change it on yours. my advice would be to go through tv menu and sub menus to see if there is one for screen size. if not go into ps3 menu and set resolution to 720p as this res is much better detail than 1080i, because the p=progressive and i= interpolated. progressive is always best
I have a TH-50PY700H TV linked to an M8S KitKat 4.4.2 Kodi TV Box but the top & bottom of the display is cut off. Can anyone help pls.
If the signal is a product of the ott box than go to settings and find display. It will tell you how to make screen size to fit your screen.
Aug 19, 2017 | TV Box Televison & Video
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
How do I enter the service menu on an Emerson EWF2004 CRT Television? (Pictures of the OVERSCAN ISSUE will be provided if needed.)
Older sets had vertical and horizontal size controls. If you have the horizontal size control, turning it counterclockwise will reduce the size of the picture horizontally and reduce the overscan.
Feb 25, 2016 | Emerson EWF2004 20" TV
KLV-S32A10 overscan problem, only have "wide" zoom mode.
Go to settings and use anything other than wide option. Setting there - just look for it.
Feb 21, 2016 | Sony KLV-S32A10 32 in. HD-Ready LCD...
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
Overscan
Yes, if you have the original remote and get into the adjustment menu which is hidden you can adjust width, height, and centering if you want.
Dec 09, 2012 | Mitsubishi VS-50111 50" Rear Projection...
Projection off the screen?
Try pressing the "Aspect/Prog -" button on the remote - it should be just underneath the number 9 key - try pressing once, see if it fits better, try pressing again to see if it improves until you get a better match
Feb 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Feb 06, 2008 | Philips Magnavox 42MF521D/37 Television
Overscan Problem
Switch to that input, and run the Auto Convergence for that input (Setup menu on the TV, Convergence). Convergence settings save for that particular input.
Dec 06, 2007 | Televison & Video
Toshiba 55H70 55" Rear Projection Television Logo
630 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
