Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
LG GR-S702ABQ Fridge
My fridge is a 5 years old, working with no problems. Yesterday I found it has sort circuit. Checked the cord and it is fine. Any advice whereto start or what to do?
Thanks
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
  • 400 Answers
SOURCE: LG GR-292R freezer works/fridge does not.
It is more than likely short of refrigerant, needs to have the leak repaired and then recharge refrigerant.
Posted on Mar 05, 2009
  • 6 Answers
SOURCE: Fridge too warm....
the fridge is short ov gas it should cost about 60 pounds to repair
Posted on Apr 23, 2009
LFX25974ST. Why does it have no power?
check for broken thermostat connection and compressor overload loose connection. check power cord plug. check continuity of power cord. with all of these found good, check connection to the control board. if good but still no power change the control board. thanks .
Aug 17, 2015 | LG Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
My lg refrigerator just gave out. Its plugged in but its not working. I have checked the circuit brakers and everything is fine. Is this fixable or do i need a new fridge? I have owned this one 2 years
I had this problem a while ago. It may not be the circuit breakers but the outlet where fridge is plugged may have gone bad. Plug fridge into another outlet and see what happens. A 2-year old fridge is almost brand new.
Jan 23, 2011 | LG LSC27910 (265 cu ft) Side by Side...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
LG Bottom freezer refrigerator Model LFC21760 does not cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages
Sep 28, 2009 | Refrigerators
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
My LG LRBN20514ST Fridge is not cooling
Set the temperature to low in the fridge and reply what happens.
Also reply if items in the freezer are frozen hard.
Jan 24, 2009 | LG LRBN22514ST Bottom Freezer Refrigerator
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Jun 05, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
63 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
