Question about Pioneer Audio Players & Recorders
How to connect pionier VSX-918V-K receiver with blu-ray dvd and high definition tv box
  • 2,071 Answers
The audio OUTPUT of blu-ray dvd is to INPUT to the VSX-918V-K receiver.There are three RCA jack red and white is the audio,the yellow or blue sometimes for the video connect to your TV...
hope this may help;
Posted on Jul 25, 2008
How do I hook up a Pioneer VSX-918V receiver to Sat.Dish box?
For the audio portion, you must have either a digital coax, optical connection or analog L/R composite RCA jacks plugged into the " in" on the rear panel of the chassis. The other end of THAT connection must come from the "audio out/ variable out" from the T.V. or from the Sat.Dish box.
Sep 12, 2014 | Pioneer VSX-918V Receiver
My BD530 player doesn't play all movies clearly. Some come cover good others re all snowy
When properly connected to a High Definition display or TV, Blu-Ray Disks (BD) should play crystal clearly. Inserting an old "non-Blu-Ray" disk (or the original "DVD") in the Blu-Ray player will display a comparatively "fuzzy" picture. This is the difference between High Definition and Standard Definition. A "BD player" can not "upgrade" the picture quality on DVDs to that of a BD or High Definition picture.
Rent, purchase or choose Blu-Ray Disks (BD) whenever a choice is offered to view the High Definition version of a movie or video. Selecting the DVD version will provide the lower quality or Standard Definition version of the same movie or video.
Check the covers or disk itself to determine if the movie or video is in DVD or BD format. That will tell you what you can expect for picture quality.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 17, 2011 | LG Super Blu BH200 Blu-ray and HD-DVD...
How to hook up direct tv box,samsung hd tv,pioneer vsx-820 receiver,samsung blue ray bd-c5500
If you're using HDMI cables, which I suggest you do, this is how you set it up.
From the TV, you'll connect an HDMI cable to your receiver.
Connect the blu-ray player to your receiver.
There's a small amount of setup required with the receiver, but it's self explanatory.
Mar 12, 2011 | Pioneer Televison & Video
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Apr 19, 2009 | Pioneer VSX-D514 Receiver
Does blu ray technology work with old TVs
Yes, provided the TV can accept one of the Blu-Ray player output connection types. But there is NO advantage over DVD, the reason is that Blu-Ray is designed for 1080i and 1080p resolution high definition TV's, and you won't get better resolution simply connecting a Blu-Ray player to an old TV.
Feb 27, 2009 | DG Locks & Locksmithing
How to connect blue ray disc player to rca rear projection tv
Unfortunately, there are a couple potential problems. First of all, if you RCA rear projection tv is fairly old and is not a High Definition tv, you may not have an hdmi, dvi, or component connector cables inputs. Without these, you are left connecting your blu-ray only by the standard yellow (video), along with the audio (red and white) rca cables... either way, the High Definition portion of the blu-ray won't work with a non-High Definition tv. It may be time to buy an HD capable tv to use your blu-ray effectively...
Dec 29, 2008 | Televison & Video
146 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
