Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
Richard Gaines Posted on Jul 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black images MY KONICA MINOLTA 7D MAXXUM TAKES ONLY BLANK (BLACK) PICTURES AND CUTS OFF AFTER EACH SHOT. IT HAS PREVIOUSLY PRODUCED EXCELLENT PICTURES. iS THIS AN INHERENT PROBLEM WITH THIS CAMERA AND HOW DO RECTIFY THE SITUATION
  • 4 more comments
  • Richard Gaines Jul 23, 2008
    It still doesn't work and I also tried reformatting the card without any success
  • meng40 Aug 18, 2008
    I have exactly the same porblem starting a week ago after 2 1/2 years of very satisfying usage. The problem persisted even I recharge the battery, change the battery, removing card, reformat cards, new cards, reset to default... nothing work.
  • mpuzach Sep 28, 2008
    Same problem with my wife's Maxxum 7D. Has anyone found a solution or been successful in finding someone to make repairs?
  • raindance2 Oct 05, 2008
    Same exact problem after about 2 yrs of use.  Pulling my hair out.
  • daystarsd Oct 05, 2008
    I have the same problem. Sent off off for repair - 3 months and $200 latetr returned. Worked briefly then same problem came back. This camera has had very little use. Can anyone assist???
    Thanks a million, Susan
  • atv_rider200 Oct 06, 2008
    Same problem. Worked great for a couple years and now ... BOOM. Very Frustrating.
Amir Varamini
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 08, 2021
Amir Varamini
Contributor
Level 1:
Answers
Questions
0
Helped
656
Points
It worked but can not take long shots without lens.
I did with lense and opened the CCD.
Thanks
Anonymous
Level 1:
New Friend:
  • Posted on May 17, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
656
Points
My camera did the same thing, i used it on many fires and took some awesome photos. when my camera went blank on me, i was in a helicopter on a burn shooting like i was working for NGS, it sucks to lose my 7d, good time with it....
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jul 23, 2008
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957274
Points
33084
Try to take picture without memory card and observe that still camera goes to Off?
  • Anonymous Jul 23, 2008
    Ok, You need to contact concerned service center now for proper repair.
1 Related Answer
Anonymous
  • Posted on Mar 08, 2009
SOURCE: BLANK (BLACK) PICTURES
Yes this is a common problem. Set the camera to take a long exposure shot (5 seconds) and with the lens off take a photo. Can you see the ccd or just the shutter (black)? If its just the shutter the shutter is jammed. It's basically a question of persisting with rebooting the camera and taking shots until the shutter frees itself.
Konica minolta maxxum 7d support
This is a common problem with the 7D. The shutter curtain will stick after several years of service. Put the camera in clean mode to get the curtain to lift, or send it to Sony to replace it. It was a design flaw by Minolta.
3helpful
My minolta maxxum 7d won't take a picture....The shutter will push down but no picture will be taken. I tried it later in the day then it worked. Now today I tried, it worked this morning and then not...
Precision Camera picked up the responsibility for fixing the 7D and 5D Konica-Minolta cameras when Sony bought out K-M. I contacted them when my 7D wasn't functioning, and sent them my camera. Fortunately, on of the problems was "First Frame Black". Precision completely refurbished my camera and returned it to me in better than new condition. Sony picked up the full cost for the total refurbishing; all I paid was the shipping cost to Precision. I might add that my 7D was not in warranty. The URL for Precision Camera is:
http://www.precision-camera.com/ . Give it a shot.
5helpful
symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
symptom 2: Camera does not respond at all to the shutter release. Focus is fine, menu works, every function works no problem except for the most important - taking a picture (releasing the shutter). When you first turn on the camera, you hear the Antishift module attempt to center the CCD with a series of clicking noise for 5 or so seconds (not a good sign, also called the death rattle). All 5 AS bars in the view finder are blinking. In this case, the Tebure Assembly (AS Module) has failed and will need replacing. This is not cheap - sending it in to Precision Camera will run you around $250-$280. You can do it yourself if you order the assembly from Sony: Item - ( TEBURE ASSY ), U3008233U, $118.22 ea. via 1-800-488-7669 (will take 3-4 weeks). And follow the service manual to install and calibrate it (via the service manual download at http://www.dyxum.com/dforum/topic36109_post396839.html#396839).
However, if your camera experienced the FFB and then siezed (symptom 2) you can probably still get Sony to repair it free as its one charge for a complete camera repair. Call them up and tell them your situation.
Jul 23, 2008 • Cameras
5helpful
3answers
3answers
CAMERA PROBLEMS
I had the same problem. Took picture; camera turned itself off after one shot; review of picture showed no image (black). Thought it was battery or card but battery fully charged. Took card out; turned camera on; activated shutter; camera turned itself off. Reinserted (same) card; turned camera on; took picture; problem solved. No idea why. Gary
Lack of image
There is a known problem with the 7D and some early 5D's where sometimes when you turn the camera on and take a picture it is all black and the camera locks up. You can turn it off and back on and the problem goes away for awhile. Don't know if this is what ou are experiencing. If it is, Sony (who bought out Konica Minolta's camera division) will fix the problem for free. Just had this repaired on my 7D.
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
