Contributor
- Posted on May 10, 2011
Re: How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
- A small Phillips heads screw driver
- A pin (or needle)
- A replacement CR2032 battery
Instructions :
- Remove the 4 screws from the back of the watch
- Carefully remove the back plate, do not damage the delicate rubber seal
- Carefully remove the delicate rubber seal
- Use the pin to remove the small rubber block from the battery cover clasp.
- The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
- Use the pin to gently pull back the clasp of the battery cover.
- The battery cover will then open with a 5mm gap approx. It does not need to be removed.
- Use the screwdriver to remove the battery.
- After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
