Ihave a toshiba hdplayer model no,hd-ep30kb.starts up with welcome winder and thats it,plus it will not turn off i have to unplug it from the wall socket R.L.W
  • dropdown Jul 23, 2008
    toshiba hdplayer model no.EP30KB WHEN I SWITCHED IT THE WELCOME SIGN COMES UP BUT WILL NOT GO ANY FURTHER,AND I CAN NOT TURN BACK OFF UNLESS I PULL THE PLUG OUT FROM THE WALL SOCKET
    R.L.W
  • 2,071 Answers
This a "hang up"trouble.If your unit is not cover to warranty,you can do-it-yourself repair.Open the player,reheat the circuit board by using a hair dryer and avoid the plastic connector to be direct hit by blower,that it and it will work ,this is tested already for that kind of trouble.message whatever the result..
Posted on Jul 23, 2008
    Master:
  • 382 Answers
Try to hard reset the device..Keep it unplugged for 30 mins or an hour and then plug it and try then..Also The problems looks like some problem on the board which might have occured due to overflow of current..So if possible call a service person to check the board for any burnt or short circuited Ic's etc..Hope this helps you!!..thank you..
Regards!!..
    Guru:
  • 1,894 Answers
This welcome screen problem is a quit old problem.
is there no reset button behind your player?
  • dewan nafees ahmed Jul 23, 2008
    first of all leave the unit plugged off from wall power for one night. and then try powering it ON. see if the problem exists.
    if yes then proceed.
    --->Try pressing the power on button on player and holding in in for over ten seconds. This will force the player to boot.(forced shut down and restart)
    --->Go to Setup menu, then Maintenance, then select initialize. Tell me if
    this works. All settings will go back to manufactured specs and memory
    will be cleared. Firmware update will still stay.
    There are no magic combination of keys to press
    so if your unit is under warranty then send it for a replacement.
    else take it to a repair shop.
    thank you
  • 13,433 Answers
First things first, if its still covered by warranty have it checked or repaired for free by your dealer or manufacturer.
If there is a reset button in the back press that, it would seem like a software problem.
I wound my bobbin on my model 1100, pulled it out, treaded the machine, and cannot stop the bobbin filler from turning. Now the machine does not want to sew. Help.
Sounds like the bobbin winder activator is stuck. As long as the bobbin winder is activated, your machine will not sew since that is a safety function.
You might try flipping the bobbin winder activator back and forth and see if that releases it--or try winding some other bobbins. If it will not release, then you may need to take the machine for service.
If the bobbin winder is worn or defective, you can look at purchasing a stand-alone bobbin winder (called "Sidewinder") available online through Amazon, JoAnn's, etc. for about $30. It saves wear-n-tear on your machine plus allows you to quickly wind multiple bobbins without unthreading the machine. You can get battery operated or one that also has an AC cord.
Sidewinder bobbin Google Search
Oct 02, 2017 | Sewing Machines
How do I fix the bobbin winder on the 155. It has stopped working completely.
Unable to provide advice without the make & model.
However, in the meantime, you can purchase a stand-alone bobbin winder at the local fabric store or online for ~$30. One brand is called "Sidewinder." Be sure to verify that it will work with your machine's bobbins as some bobbins do not fit!!!
FWIW, it is nice to have a separate bobbin winder so you don't have to stop in the middle of your project, remove the thread, wind a new bobbin, and then rethread the machine.
Sep 30, 2016 | Sewing Machines
My toshiba regza model 32wl68p is difficult to turn on from standby.Ihave to unplug in and retry numerous times before it turns on
Please replace bad capacitors in power supply board or replace complete power supply board available HERE to solve tv problem.
Thanks.
Jun 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
My Toshiba HD tv will turn itself back on after I shut it off with the remote. What should I do
The processor might have some garbage in it do to a power surge and if you leave it unplugged for 40 MIN. from the wall , it will reset back to normal.
Jan 13, 2011 | Toshiba 55ZX900 55 in. HDTV-Ready LCD TV
I hv a flt screen hd tv and it won't turn on, it saystimer rec can i fix this
Hi there
Unplug from wall, wait 3 minutes and then power back up. This should reset any sytem timer. Then go into menu and turn timer functions off.
Hope this helps
TV_Doctor
Jan 03, 2011 | Toshiba Televison & Video
I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Mar 26, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
All i get is the welcome screen and no light by the standby button. it has power
If normal operation has the welcome screen dissapear after a few seconds followed by working properly, it appears the internal software is corrupt or buggy.  Try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this doesn't resolve it, the Toshiba will require service for defective software.
Mar 26, 2009 | Toshiba SD-H400
I have a toshiba hd player when i turned it on the welcome sign came up but that was all,and i could only turn it off by removing the plug from the wall socket ...
as it is still under warranty i have contacted toshiba as one of your experts advised and they are looking in to it as to what course of action is needed. thank you for your help
R.L.W
Jul 23, 2008 | Televison & Video
Frozen A30
Hey wingnutz,
If your HD-DVD player has been locking up after a recent firmware update, you may wish to attempt rebooting/resetting the unit before considering any kind of repair option.
First I would suggest seeing if you can enter the "Setup" menu from the "Welcome" screen. If you are able to do so, under the "Maintenance" option there should be a command called "Initialize." After selecting this command, you will need to turn the player off and unplug it for several minutes. This should cause the unit to reset.
If doing so does not resolve the problem, you may wish to then look for a pinhole reset button on the back or underside of the player. Typically players that have a reset button will return to their original factory settings when this button is depressed. Please keep in mind that not all HD-DVD player models will have such a feature, so you may wish to refer to your owner's manual documentation for more information.
Alternatively, many products (DVD players, computers, etc.) will have what is often referred to as a "soft reset." This is typically done by pressing and holding the power button down for 10 to 15 seconds.
Should your player still be stuck on the "Welcome" screen after trying all of these, you may need to contact Toshiba or a local repair technician for further assistance. Remember that if you are unsure where your local repair facility is, you may always obtain service and repairs by bringing your player into your local Best Buy™ store.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 08, 2008 | Toshiba HD-A30 HD-DVD Player
Toshiba 55" 55H70 model. Turns OFF, but won't turn ON until I unplug it from the wall first.
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 22, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
