Question about Refrigerators
I have a frigidaire frs20zrg, im having problems with the water dipenser, water coming out very slowly, can you help
  • Anonymous Aug 04, 2008
    ice maker clogged
  • mchljll Jan 02, 2009
    after a power outage, the water dispensed extremely slowly- and now not at all. Plus the ice maker stopped working. Plumber thinks its a motor, but which one?
2 Suggested Answers
  • 2679 Answers
SOURCE: Frigidaire FRS20ZRG Ice is collecting in the
sounds like the drain is blocked,melt out the ice with a hair dryer until you can remove the bottom bin or draw,and remove the second drawer or bin,look at the inside back wall of the freezer and follow it down to the bottom,if you can't see the drain hole you'll have to remove the wall to get at the drain,slime and food gets stuck in the drain and when the machine defrosts the ice that melts off of the evap coil turns to water and it goes down the drain and down into the pan where it evaporates from the heat of the compressor and condenser but when the drain gets blocked the water has nowhere to go but onto the floor of the freezer and eventually onto the kitchen floor,i use a steemer to blow out the drain hose if you don't have one melt out as much ice that you can and pour hot water into the hole,with something like a turkey baster or anything that will push through the drain will work,when you think it's clear pour more hot water into the drain,if it goes down you're done if not keep at it until the water drains through.hope this helps
Posted on Oct 21, 2011
Water is leaking from the dispenser area as well as the bottom of the freezer door of frigidaire frs20zrg
Hello Dc2464, thank you for your inquiry!
Based off the information you have provided water is leaking from the dispenser as well as the bottom of the freezer door. This is where your water line is located and it is possible that there could be a leak. I would recommend contacting a professional technician for proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jan 14, 2016 | Frigidaire Refrigerators
Model frs20zrg. How do I get to freezer drain plug?
It's a tube, not a plug and it's located inside at the bottom rear.
Dec 04, 2015 | Frigidaire Refrigerators
Water will not dipense water
What is the model number of the unit?
Nov 07, 2012 | Hotpoint Refrigerators
FRIGIDAIRE FRS20ZRG STOPPED WORKING AFTER MOVING IT, LIGHTS STOPPED THE NEXT DAY
It may have been defrosting on a timed cycle when the compressor stopped. If any water was present at the time, it may have seeped into the electrics. Check the fuse and you have power to the on/off switch and thermostat.. If fuse blown, check all is dried out before plugging back in.
Apr 21, 2012 | Frigidaire Refrigerators
Just had a new part # 241734301 installed, because the old one broke during a move. It appears to work fine although the water continues to dribble for a while after filling a glass. Also, the water will...
It seems as though the water hoses are reversed, Ice maker line and water dispenser line are probably switched, this would explain why the water comes out the door intermittently. It's probably trying to dump water into the ice tray but its coming out the door.
May 22, 2011 | Frigidaire FSC23F7D Side by Side...
Ice maker dispenses ice but the water dispenser does not dipense water help!
the water line may be frozen / if so you can adjust the tempt and in 24 hr it may start working / if that does not correct problem ck the dual valve as the water side may be burned out .. mm
Jul 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire fdb510lcs0 soap dispenser not opening
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once poweris applied to it. The BI-metal strip bends and allows the soap door spring toopen up the dispenser. This bi-metal strip is not given full 120 volts power,the timer "shunts" the power through either the heating element (most common ) or the motor and this gives the bi-metal strip lower than fullpower to work and open. Most often the bi-metal strip has lost its ability tobend properly and needs to be replaced. Older GE dishwashers used a mechanicalarm driven by the timer to open the dispenser = no electrical bi-metals.
Newer Frigidaire dishwashers and many newer Whirlpool dishwashers use a wax motor to open the soap dispenser. The plunger insidethe wax motor slowly moves and pushes the plunger and door open. And, if thiswax motor doesn’t receive 120 volts, then it’ll not work.
This will help you --
Please do rate this solution and revert for furtherassistance.
Thanks
Rylee
Sep 20, 2009 | Frigidaire Dishwashers
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Refrigerators Logo
253 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
