My beko washer 1512s is just clicking through the programs
    Guru:
  • 1,894 Answers
Does the clicking noise come up while start up?
and what about the other cycles?
does it proceed?
Posted on Jul 25, 2008
    Sergeant:
    Champion:
  • 310 Answers
Just turn off for one day and turn on........it will be clear.............
3 Suggested Answers
kjmac
  • 97 Answers
SOURCE: beko 1512s problem
hiya
sounds like there is a fault on the machine, when the timer starts clicking the doorlock light will flash a number of times, you will need to count these flashes as this will give an indication of the fault.
hope this helps
please dont forget to rate this answer. thanks kj
Posted on Jul 31, 2008
blueextc3221
  • 15935 Answers
SOURCE: instruction manual for a beko 1512s eco care washing machine
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!
Posted on Sep 16, 2010
Beko wma 1512s not heating up and ive replaced element still not working?
possibly bad gas valve or your venting is clogged with lint.go on the outside of your house and make sure the air is blowing out strong
Nov 09, 2013 | Washing Machines
My beko washer is going straight to spin cycle
Try to reset it: turn it on, push start button, then program (any program) is started and push and hold start button for 5-10 seconds.
Drain program should start.
Apr 03, 2013 | Beko Washing Machines
I have a beko 1512s washing machine, it goes thru the cycle but then wont do a final empty and spin. Its not the pump and its not the brushes please help :(
Are you refering to the main motor when you say 'Its not the 'pump' and its not the brushes' or have you been able to check the separate drain pump and clean the filter, please?
Because I do not know your answers and just in case with no promises ;-0) ---------->
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 16, 2011 | General Electric Washing Machines
My beko eco care wma 1512s has stopped working completly at first i had power but nothing was working then l slammed the door and the trip switch went on my electric went and then the fuses kept blowing...
Sounds like there might be a sensor in the door catch that may have been broken or dislodged and is leaking to earth causing it to trip. Most machines have this sensor as a saftey device in the door catch. Check and see if this is the problem.
Oct 25, 2009 | Washing Machines
Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
Apr 29, 2009 | Washing Machines
Instruction manual for a beko 1512s eco care washing machine
CLICK HERE
Apr 01, 2009 | Washing Machines
Beko washer
hi there.....this problem can occur with the W510 if you have selected the 30minute wash and loaded a full wash load....the 30min wash is to be used with a 2.5 kilo load only.....if the problem is occuring in other selected programs then you can check (a) is the machine draining...if not check filter and pump..(b) check the motor plug that it is secure....remove it refit and test.....check the carbon brushes in the motor....and lastly if al the above are ok then you got a faulty PCB Board.
regards Sir Galahad
Jul 29, 2008 | Frigidaire FTF530FS Front Load Washer
Beko 1512s problem
hiya
hope this helps
Jul 25, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
