Cobweb in projection tv
I have a panasonic PT47WX42F and I just noticed a cobweb behind the screen. Since I just paid $375 to have the convergence IC's swapped out I'm reluctant to have the service guy come again for this.
In examing the chasis I see that there are a series of screws that look like they hold the chasis to the screen portion, but I'd like some advice if thats the best approach or should I pull the back service panel and try to get to the back of the screen from that point.
  • 45 Answers
Take the back cover off as the mirror is attached to it then you can clean the mirror and the inside screen and colour gun lens's (3off) there should be 8 to 10 screws around the outer edge of frame and about 6 to 8 holding the screen portion to the chassis
Posted on Jul 23, 2008
Can the front cover be removed for cleaning?
yes normally its just small clips that are resealable used to hold it on as for maintenance it requires exposing the light bulbs
hope this helps
Robb
Apr 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
I have a 61'' Panasonic tv that is showing green and red outlines around the figures on the screen. It originally started as just green outlines. Any ideas on what the problem is would be great. Thanks
The convergence is off. The convergence is basically the assimilation of the image on the screen from the three "guns" behind the screen. There should be a menu option to align the convergence in the image portion of the menu. If this does not fix the issue, then your convergence chip might be on it's last leg.
Oct 23, 2009 | Panasonic Televison & Video
Our panasonic HDTV-model #PT47WX42F all of a sudden has 3D images- I've tried to correct with the convergence buttons but can't get the colors aligned--can you suggest something to try or is it...
You can repair that issue by installing a convergence repair kit. You can get the repair kit for your model which has the parts and detailed instructions at the following link listed under the Panasonoc repair kits. www.tvrepairworld.com
Aug 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My tv is over lapping colors on the words
Convergence needs to be aligned try in mune under setup, if will not aglin the its bad convergence IC's, need tech
Aug 09, 2009 | Panasonic PT-47WX53 47" Rear Projection...
My pt47wx42f model panasonic tv attempts to turn but fails
Thats the error code for the convergence. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the parts and detailed instructions on how to install the kit.
Aug 08, 2009 | Televison & Video
Panasonic PT-60LC14 Convergence Issue
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 06, 2008 | Panasonic PT-60LC14 60" Rear Projection...
TV not staying on
I called a tech and it was a convergence issue. It cost $375 to fix.
Jul 05, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Mar 22, 2008 | JVC AV-48WP30 48" Rear Projection...
Exploded view diagram
1) Remove rear cover. Slide out pressed-board light shield.
2) Remove any cobwebs behind screens-(soft cloth on pole)
3) wipe lens caps with soft cloth
4) re-assemble
Oct 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
Electro Med Services...
