Question about Motorola XU2600 (6 Channels) 2-Way Radio
Parts for XTN Series Motorola Radio
Having trouble finding replacement parts for the case and buttons on XTN series radios, model #XU2600.
I know it's discontinued but I have 30 units in operation now and needing replacement parts.
  • Motorola Master
  • 1,654 Answers
Call us here at eradiostore 800-872-2627, we can help.
Posted on Jul 23, 2008
  • eradiostore
    eradiostore Jul 24, 2008
    The sister radio to the XTN, the Radius CP100, is still available in the 1 channel version. (As of the date of this writing.) Parts are still available for both models. Parts usually are available for 5-7 years following the discontinuation of a radio. Many times the radio will share parts with another model, which will give availability even more time.
Frecuencias radio xtn xu2601
The frequencies programmed into the radio vary by the Country the radio was to be sold in. For instance, the frequencies for the XTN for the USA is different than the frequencies available for Canada. What is your question? How to program or what are the frequencies?
Mar 03, 2014 | Motorola XTN UHF Two-Way Radio Series
How to set channels to be thesame on all motorola xtn series radios
Here is a link to the user guide for the XTN style radio. http://www.123radios.com/manuals/xtnmanual.pdf
Programming instructions begin on page 18. You will need to set the frequency and interference eliminator code (PL code) the same on all the radios.
When you enter programming mode, you can use the menu button to walk you through the various options you can program.
Best regards.
Nov 21, 2012 | Motorola XTN 2-Way Radio
Xtn series won't transmit through remote microphone
Here are a handful of problems you might be having:
1) Be certain the radio is turned OFF when plugging in an audio device.
2) Be certain the remote mic is plugged all the way in, until you feel a slight click.
3) Your accessory jack could be wobbled or worn from plugging and unplugging chargers/audio devices. If so, the radio would need repair.
4) Your remote mic is not working. Try it on another unit to confirm.
5) Or the remote mic is not the one designed to go with the XTN radio.
Best regards.
Jun 18, 2012 | Motorola XV2600 XTN Series Portable...
Were can i find software for 448 xtn motorola radios?
Hello Harry,
I checked the manual for this 2 way radio, and I don't think there is anything like "software" in this context.
The firmware has been hardcoded to the hardware itself.
If you could explain your issue in detail, perhaps I can be of some help.
You can refer to this manual if you want: http://www.scribd.com/doc/15685467/Motorola-Xtn-Series-Userguide
If that's not the problem, then let me know. I'll be glad to help you out.
Please rate this solution if it helps you.
Mar 18, 2011 | Motorola XTN 1-Watt VHF Business 2-Way...
Have a Motorola 2 way walkie talkies but misplaced the manual on how to operate the unit. Bought these at Canadain Tire about 5 yrs. ago. Not sure if 1XTN4004B or CH600 is the model number. Please advise...
Haven't been able to locate a user guide for the multi-unit charger. However, it is pretty much plug-in-n-play. It can charge a battery inside a radio, or also accommodate a battery alone in each of 6 cups. As for replacement parts, they are not available, and you cannot purchase the multi-unit tray separate from the power supply. This is a slow rate charger and would take 10 hours to charge your batteries (or overnight). Radios/batteries should only be placed on the charger when nearly depleted. (Consider your charge a place your radios go to bed overnight.)
If you are having difficulty with charging, clean your battery contacts on the exterior of the radio and inside the charger cups with a pencil eraser.
This tray can act as a radio cloning station. See page 23 about cloning in the XTN radio user guide: http://www.123radios.com/manuals/xtnmanual.pdf
Best regards.
Jan 09, 2011 | Motorola XTN-Series Multi-unit Charging...
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
Nov 03, 2009 | Motorola XTN Series Pro Two-Way Radio...
No user manual for the RDV2080d
Here is a link to the programming software http://www.radioserviceincorporated.com/files/1935423/uploaded/RDX_Series_CPS_R01-00.zip
And here is a link to the user guide http://www.astracomm.com/media/pdf/RDX_Display.pdf
The RDV2080 VHF with display would be compatible with the XTN series radios which have a model name starting with XV, as in VHF. Typically the RDV2080 ships on the default frequencies found in the XV2600. So if you have not changed your XTN frequencies/PL code they may match out of the box.
On a sidenote: The Motorola CP110 VHF is also compatible. It is an industrial version of the RDX radio. It has a few more channel capability and a replaceable antenna. It looks just like the RDX models, and it is the replacement radio for the CP100 and/or XTN.
All of the above mentioned models are repairable.
Jul 20, 2009 | Motorola RDV2080d Two Way Radio
I'M WORKING ON MY XU2600 RADIO AND MY VOLUME CONTROL WILL NOT REACH MAXIMUM INTENSITY AFTER REPLACING MICROPHONE AND EAR PIECE JACK.IT'S LIKE IT ONLY HAS HALF THE VOLUME.ANY REMEDY? ALSO ANY SCHEMATIC...
Schematics were never offered for the XTN and CP100 line of radios. You may have a speaker or volume potentiometer issue. Check both of these items. If this is not the issue then your radio is possibly non-repairable. Low Rx volume is known to occur on some XTNs, usually in conjunction with running the radio at full volume for extended periods of time. This low Rx volume issue can be corrected about 50% of the time by a qualified service center.
Jul 15, 2009 | Motorola XU2600 (6 Channels) 2-Way Radio
Programing radios
The XTN will not work with the spirit. The PL tones are worng.
Feb 21, 2009 | Motorola Walkie Talkie 2-Way Radio
Motorola XU2600 (6 Channels) 2-Way Radio Logo
311 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
