Question about Zanussi ZWF1440 Front Load Washer
ZANUSSI ZWF 1240W
GETTING THE FAULT CODE E50, please advise
    Problem Solver:
  • 6 Answers
This is control modula fault. you will need to replace the module. http://www.espares.co.uk/part/p/0/0/0/0/566534/pcb-configured-ewm2000evo.html?k=zanussi+zwf1631w
Posted on Aug 05, 2008
My zanussi ZWF 1631 -W is showin fault E50 ..any idea ??
Hopefully answered on your other posting ;-0) John C
Sep 10, 2011 | Zanussi ZWF1630 Front Load Washer
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
I have an E50 showing on my zanussi 1217w, whats the problem?
I do not have E50 listed as a fault code but at a guess the motor brushes are worn out as the E50`s i have listed are all to do with motor problems-first place to make a start to solve your problem.Turn power off first please!!!!
Dec 29, 2010 | Washing Machines
ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
Jul 24, 2010 | Zanussi ZWF1430W Front Load Washer
Error code E 31 on a zanussi zwf 1431 front loader machine may not be water in. water feed and filter ok
The code E31 relates to a problem normally with the pressure switch,heater or maybe the Programmer.The heating element may even check out with a test meter but it can be an earth fault and normally just replacing this part cures the fault.If you are not electrically competant it would be worth getting it checked.
Hope I have helped.
Apr 25, 2010 | Zanussi ZWF1430W Front Load Washer
Can you tell me what code E50 is please?
Yes E50 indicates that there is a fault on the main motor.This hopefully is worn carbon brushes which can be replaced at reasonable cost.If the main motor is faulty and this machine is out of the 5year parts warranty (2004 from mod. no.)It would be costly so check the brushes first.
Hope this helps.
Good Luck.
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1440
Something wrong with the pump,leave out let hose down as flat as possable into a basin or whatever,to drain water,remove pump test and check it.
Sep 05, 2008 | Zanussi ZWF1440 Front Load Washer
Zanusi zwf 1631 w wont work
all of the e50 codes indicate motor check your brushes. if you still have problems email me
Feb 10, 2008 | Zanussi ZWF1630 Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
593 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
