I have a toshiba hd player when i turned it on the welcome sign came up but that was all,and i could only turn it off by removing the plug from the wall socket R.L.W
As it is still under warranty i have contacted toshiba as one of your experts advised and they are looking in to it as to what course of action is needed. thank you for your help
R.L.W
Posted on Jul 24, 2008
2 dvds in built-in player
I have come across this a few times, one in fact last week!! The back needs to be removed from the back and the dvd section removed, Dont be afraid this is quite easy to do. lie the tv down face first and remove the stand and all screws, then remove the DVD section, should be 5 x screws and some leads that just clip off.
Then you will need a small screwdriver or a knife to prize the second dvd out, this may scratch your dvd but its better than your dvd player being broke!
Once out place the dvd player back in the set then re-screw it plug the leads back in and turn the set on and try to eject the first dvd, this should now be ok.
Once done, turn the tv off and replace the back on.
Just take your time and Obviously make sure the tv is not plugged in when removing the DVD.
Hope this helps
Apr 05, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Converting Toshiba HD E1 DVD player to codefree
Hey! It is possible to convert your Toshiba HD E1 DVD player to region free. But you need some DVD Copy software to help you remove the region code first and then burn it on a new DVD disc. Thus you can play it on your DVD player. I recommend you use this DVD Copy which is very esay-to-use.
If you want to watch your DVDs on PC or some portable palyer, you can use some DVD Ripping Software which can remove CSS protection from DVD and convert DVDs to video palyable on PC. You can have a try of this DVD Ripper.
Hope that helps.
Nov 29, 2009 | Toshiba HD-E1 DVD Player
Their is a disc stuck in my Toshiba HD-XA1 plyer.All it says is ''welcome''.I tried to unplug it but still did not work
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Use a stiff wire,a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
To open the DVD player top to remove the cd/dvd manually--
  • Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
  • Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
Points to remember while performing above steps---
n Before you remove the DVD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
n Use the opportunity while you have the outer casing off to clean the lens of your DVD player.
n Never work on an electrical device that's still plugged in.
n Opening a DVD player may negate the warranty. Read yours carefully before you proceed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Toshiba HD-XA1 DVD Player
Toshiba 52 inch TV turns on then blacks out.
Unplug the power to the TV and HD cable box, wait 5 min. Plug TV and HD cable box back in.Everything is working like new. Go figure.
Sep 29, 2009 | Toshiba Televison & Video
Frozen A30
Hey wingnutz,
If your HD-DVD player has been locking up after a recent firmware update, you may wish to attempt rebooting/resetting the unit before considering any kind of repair option.
First I would suggest seeing if you can enter the "Setup" menu from the "Welcome" screen. If you are able to do so, under the "Maintenance" option there should be a command called "Initialize." After selecting this command, you will need to turn the player off and unplug it for several minutes. This should cause the unit to reset.
If doing so does not resolve the problem, you may wish to then look for a pinhole reset button on the back or underside of the player. Typically players that have a reset button will return to their original factory settings when this button is depressed. Please keep in mind that not all HD-DVD player models will have such a feature, so you may wish to refer to your owner's manual documentation for more information.
Alternatively, many products (DVD players, computers, etc.) will have what is often referred to as a "soft reset." This is typically done by pressing and holding the power button down for 10 to 15 seconds.
Should your player still be stuck on the "Welcome" screen after trying all of these, you may need to contact Toshiba or a local repair technician for further assistance. Remember that if you are unsure where your local repair facility is, you may always obtain service and repairs by bringing your player into your local Best Buy™ store.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 08, 2008 | Toshiba HD-A30 HD-DVD Player
Toshiba HD Dvd Player
I have heard about this but mostly with WalMart, not sure about the others nor with the timeframe. To my understanding there was a "Memo" to this effect (pdf.gif Walmart HD DVD return.pdf). You can get more information from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Toshiba HD-A2 HD-DVD
Multi Region Toshiba HD-E1 DVD
RCE Hack.
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
When player is turned off, this setting is cleared.
Mar 14, 2008 | Toshiba HD-E1 DVD Player
Toshiba HD A2Ku
It will take almost a minuted for the player to boot up and appear on screen, providing I am assuming you have your TV set to DVD setting.
Your DVD then when booted up will say "No Disc" if you dont have a DVD in it, course with one in it, your movie should appear.
Jan 16, 2008 | Televison & Video
Toshiba hd dvd A20 remote codes
i am having the same problem with the HD-A2KU hd dvd player not recognizing any of the codes. it seems that the dvd player does recognize the codes but will not control the player. when i click the on off button the dvd player changes to a word but does not turn it off or control it.
Oct 30, 2007 | Toshiba HD-A20
Owners manual
Hi! Dear I have Owners Manual I can email you Also can you explain me how to open Gigabeat to remove battery and HD Please email me at PATELJITU28@hotmail.com I will attached manual once you provide me your email Thanks Jitu
Sep 01, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Televison & Video Logo
Top Televison & Video Experts
