Question about GE Refrigerators
We have a model TFX271 26.6 Cu Ft no frost refregerator freezer. the problem is the refregerator side is'nt cool enough. the temperature stays aroound 60 degrees.
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
Refrigerator does not stay cold. Freezer continually frosts up every few weeks, I defrost it and everything is fine till it frosts up again.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Maytag MSD2272VE (21.8 cu. ft.) Side by...
The freezer section of the fridge works but the regular side is not cooling sufficient enough to keep the food from perishing quickly
Possible that the vent is getting choked wwith frost and so the fan is not able to blown well tothe fridge to keep the temperature up.
So the possible failure of the defrost timer / heater or the thermostat is possible which might make the compressor to keep running and the frost to build up.
Sep 30, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Top refregerator not working
look for ice in back wall of freezer . this is a no frost and that means no frost .. you may have a defrost system failure .. mm
Jul 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Mar 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Trubleshoot refrigerator staying cold enough
First review the troubleshooting steps in the instruction manual. Check the freezer and frige temperature setting control knobs. Make sure the fan, coils, compressor etc. are clean. Check the door seals, especially at the bottom. If all that does not work, do some more online research (which is what I'm up to right now because I am faced with the same problem).
Sep 02, 2008 | Admiral 26 cu. ft. Side-By-Side...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
