Sound card and memory
I have an old Gateway E-3000 and I want to upgrade the memory and get the correct sound card (I have no sound)
    Sergeant:
  • 313 Answers
The Gateway E-3000 can only support up to 66Mhz SDRAM 256mb. Putting anything else you will get an error and you will be not be able to do anything else till you remove the extra memory.
As for sound the easiest to do for a computer that old is buy a sound dongle (circa $5.00)
sound card and memory - a874fba.jpgdb7d575.jpg Just put in any USB port, and you have sound (pretty good also, I have used these in the past and found to very reliable)
Posted on Jul 23, 2008
Can I upgrade the video card on a Gateway E4300 to work with Shader 3 graphics (Eve Online)? Or do I have to buy a new computer?
You only really need to upgrade the video card and the PSU (most video cards need more power than what most companies like dell and gateway provide.). So no need to buy a new computer.
Mar 22, 2011 | Computers & Internet
How to open and upgrade RAM memory of gateway netbook model LT2704u?
This netbook is really the Acer Aspire One D255. You have to pop off the keyboard, then remove 4 screws that hold the back panel in place, which will allow you to remove that back panel in order to get to the memory.
Here's a video - blurry but it tells the story: http://www.youtube.com/watch?v=6KYNTvF0-5M
A better video on removing he keyboard: http://www.youtube.com/watch?v=FoTwln2SyQ4
Mar 01, 2011 | Gateway Computers & Internet
I have a Gateway tower (gt5026e) with an Intel mobo (E210882). I recently upgraded the video and purchased a pcie nvidia card. I knew I would need a new power supply (300w wasn't acceptable for the card)...
you may have dislodged something as you carried out the upgrade - Check all the cables are seated correctly - also check the memory is correctly seated does the machine bleep at all this will give an indication of what the problem may be ------ the number and pattern of the bleeps
the next step would be to remove all unnecessary devices, like the CD , DVD , spare drives - getthe machine to a minimum state of just PSU, MOBO, CPU, Memory, harddrive, graphics and see if that boots
also as you have upgraded the video card can you put the old one back in....
Mar 21, 2010 | Dell Dimension 1100 PC Desktop
Had a old Gateway computer with Boston Digital BA735 speakers using XP. Upgrade computer to a N68PV-GS motherboard and have analog output for the speakers. How to I get the old speakers to work?
You can't, at least not with the integrated sound. The speakers only take digital input, and the Gateway had a digital sound card installed. That new board of yours has PCI slots available. You might be able to use the old Gateway sound card. I've never tried it, but XP might recognize the card and have native drivers. If not, you might be able to find XP drivers at Gateway's site. Otherwise all you'll be able to do is buy a new set of analog speakers.
Feb 21, 2010 | Boston Acoustics BA735 Computer Speakers
Want to upgrade to a new card i have old card nv34 what can i upgrde to have 160 -wattpower with 1gig memory
based on your power supply it sounds like you have an older system......without the system information ie: slot types (PCIE etc) processor, OS it is difficult to advise you correctly......sry
Jul 31, 2009 | Dell Video Card (Nvidia, 32M, NV34) -...
My gateway desktop will not start. I am getting
Time for an upgrade my friend. Unfortunately sounds like your bios chip went bad. This happens sometimes and there is nothing you may have done. And unfortunately with a system that old you will be better off upgrading to a new computer.
Apr 28, 2009 | Gateway GT5220 PC Desktop
Gateway 500x upgrade ram installation.
hi! there if your addibg a memory card check your memory speed if match to other memory card that are installed already,they should have same speed e.g DDR PC228 or SDR PC333 so check this out before installing.But if you replace the older one upgrading,switch off your computer open cover,there is slot there for your memory card bedide your processor,at both end there a lockway,unlock your memory card and pull it out all if you have several one,then insert on one slot if that is one memory card at 2gb lock it on both end.then swich on your computer check this out on your computer properties if there is change.how to do this left click my computer,click properties.regards
Mar 27, 2009 | Gateway Computers & Internet
No video after upgrading ram
Did you accidently unseat the video card? Doublecheck to see if you completely seated the RAM and make sure you installed the correct RAM for your motherboard. Hope this helps.
Jan 02, 2009 | Gateway MT3705 Notebook
Dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
