Question about Vizio L32 32 in. LCD HDTV
Vizio 32inch lcd
Alli get is a blinking light from the power on light i looked at the power supply no puffey caps any body got a good anwser on what it is
  • lucked Jul 23, 2008
    so what could it be tell me how to test the power supply tell me where to look next i fugerd as much as it still could be a power supply problom the light blinks no pic no sound is there a tech that can help or what
    Sergeant:
  • 280 Answers
Well if the inverter board is bad it won't come on... Power supply is a switced mode so even if you don't see bad caps don't mean it ain't bad.
Posted on Jul 23, 2008
My samsung tv stadby light is blinking capacitors look good on power supply
It may be the eprom (memory ic) is corrupted and needs replacing it is a job for an engineer
Apr 10, 2017 | Samsung Televison & Video
Neon c2297f blinking red light
Fuse if the light is on will be good, suspect that the set is not making it from standby to on----Power supply board is first thing to look at in that case, damaged parts OR puffed up filter caps.
Dec 05, 2012 | Televison & Video
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
TH50PZ80U two blinking lights when attempting to power on, if power button is pushed and held for several seconds after initial turn on blink code turns to ten.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_28_2012_3_09_48_pm.jpg5_28_2012_3_10_07_pm.jpg
May 28, 2012 | Televison & Video
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Standby light blinks, no picture. Takes between 5 and 10 minutes for picture to "come on"
DEFECTIVE POWER SUPPLY THERES BLOWN CAPS IN YOUR POWER SUPPLY REPLACE CAPS WITH HEADS POP UP A GOOD CAP MUST BBE FLAT .
Jun 21, 2010 | Samsung LN-T1954H 19 in. LCD HDTV
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
URGENT PLEEEEEEEAAAASE
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
regards,
Luwangula
Sep 16, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
ON OFF LED BLINKS TWO TIMES
Hi!
Sounds like you have a bad power supply board! This is not hard to do yourself, as long as you are somewhat handy! Take the case apart (back side), and look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain).
If you see this problem, you can buy a new power supply at www.shopjimmy.com or ebay. You will need the make and model, of your tv to order! Good luck, I hope this is helpful!!
Mar 12, 2009 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
61 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
