Question about Lexmark X4270 All-In-One InkJet Printer
Power problem? No lights (usually all blue) come on to indicate it's connected to power source. All cables have been checked, disconnected, and reattached. Outlet is good. Cables look good. I get a row of solid black squares across the display screen when plugged in.
    Guru:
  • 1,049 Answers
Fried...and not usually worth replacing since the printer is an inkjet. Be sure you are surge protecting both the phone and power if you are using this to FAX.
Posted on Jul 23, 2008
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
Tip
How to Reset Counter Canon i355 printer?
There are twomethods as follows :--
  • Method 1 : Manual for service mode
  • Unplug power cable from electric source and USB cable from computer.
  • Open the printer cover and hold power button.
  • Connect power cable to the electric source.
  • Close the printer cover then release power button.
  • Method 2: Manual for service mode
  • Turn off the printer. And disconnect the printer cable.
  • Press and hold the POWER button, turn on the printer.
  • The indicator LED should be green.
  • Press and release the RESUME button , the indicator LED should be orange.
  • Press and release the RESUME button again, the indicator LED should be green.
  • Release both buttons.
This will help.Good Luck.
on Mar 10, 2010 | Audio Players & Recorders
When I turn the TV on it goes to the blue screen but nothing works then the TV powers off on its own.
Blue screen usually indicates no input. Check the input selection. Check the cables from the source. If everything is correct, try this: unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and try again.
Apr 18, 2011 | Mitsubishi LT-52153 LCD TV
When i switch on my pc the monitor display a blue power light for 5 seconds and then it turns to orange and nothing displays on screen.
Make sure you have connected the Video cable properly, Please disconnect the Video cable from the Computer and connect the monitor only to the power source. If you monitor shows anything like "Check video cable" or "No Signal" that means the monitor is working fine. You just need to connect it properly to the computer
For any further assistance feel free to get back with your comments .
Thank you for choosing Fixya
Nov 01, 2010 | Acer V193w LCD Monitor
Does not power up - battery indicator blinks amber 3 times on pushing power button
The blinks usually mean low battery. Did you connect your power cord and try starting up. Or if you have a different problem. Do as follows
  • Disconnect battery and connect only the power source
  • Disconnect power source and connect only the battery
  • Connect both and test if the battery is charging up
This will help us know if there is an issue with the battery or the power adapter.
Nov 03, 2009 | Computers & Internet
Hp laptop will not power up...at all. In fact the
1) You need to check the power supply itself to mkae sure it still puts out the DC voltage as indicate on the power supply.
2) You may have cracked solder joints at the DC input jack of the laptop.
look here for more info: www.insidemylaptop.com
Oct 26, 2009 | HP Pavilion dv9000z Notebook
Can't get monitor to power on
I have a similar switch on mine, although mine is a Gateway. So my solution is going to assume the same indicators and functionality.
On mine, a blue-violet power switch indicates it is off, red indicates standby mode, and blue to indicate it is on and/or searching for a signal. When turned on (blue), the monitor will go to standby mode (red) after 3 to 4 seconds if it does not detect a source signal. So if you toggle the power switch to blue and it soon changes to red, you'll need to check your signal, cable, or possibly for a bad source connection on the monitor.
Oct 12, 2009 | LG L206WTY-BF Monitor
Help
Signal lost usually means the cable is lose that connects the monitor to the back of your computer.
with the computer off and unplugged , disconnect the monitor cable from the video port on the back of the computer and physically inspect the pins to make sure they are not bent on the monitor end.
some monitors have the same plug on both ends , so it doesn't hurt to check the monitor side of the cable.
Once the cable has been checked, if the cover is off the computer, i would check all cables and add-in card to make sure they are fully in thier slots and ports.
check memory for the same issues.
If your monitor is a multi-function device , make sure you didnt forget to hit the source button on it , could be on the wrong input.
Oct 23, 2008 | E-Machines eMachines Desktop PC
My HP Pavilion dv6000 the wireless connection stopped working and the light does not go blue to connect to internet. This happened 2 days ago. I can connect using a cable.
Check if it is only a software problem. Usually the blue light indicator functions with the physical slider switch. So even it is disabled in the network properties the indicator still lights when the physical switch is at "on" position.
Sep 25, 2008 | Computers & Internet
Blue screen when in TV mode, hace HDcable
Blue screen indicates you have no signal/source. Double check that the signal source good. Replace cables if you can, make to look closely at both ends of cable. What is your signal source cable, sat.,?
Feb 23, 2008 | Mitsubishi WS48511 48" Rear Projection...
Lexmark X4270 All-In-One InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
