GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Feb 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jvm1650cb003 has power to unit, fuse is good, all items function, but will not cook or heat items
Anonymous
Level 3:
  • Master 403 Answers
  • Posted on Feb 11, 2011
Anonymous
Master
Level 3:
Answers
403
Questions
0
Helped
107157
Points
1133
IF the microwave is making a humming sound, then the diode is bad and needs to be replaced. If it sounds normal, but just not heating, hen the magnetron is bad and needs to be replaced.
Anonymous
Level 3:
  • GE Master 43,501 Answers
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10844740
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
1helpful
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
1helpful
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Err3 ?
"ERR 3" means that the magnetron units have failed in the microwave. Food will not cook or heat up when the microwave is in use.
The magnetron is the main source of power and heating in a microwave. Magnets work inside a magnetron tube to create the heat and voltage needed to cook items.
Prevention/Solution: Bring the microwave back to the retailer or a repair shop for service. You may also consider purchasing a whole new microwave if the prices are cheap enough.
Good luck.
3helpful
Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This is use to reheat dinner plates and left overs. Be sure that you do not use any plastic foam or metal plates/utensils this can cause damage to the unit and may cause injury.
Auto Defrost: This is used to defrost food by weight and type. EX: If you have 1 pound of chicken, meat or fish press in the food code by using 1,2,3 and then the weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This is use with the Rapid defrosting method for 1.0 pound frozen food. If you have a pound of meat, chicken or fish press Quick Frost and it will defrost for that weight only.
Cook Time: This is to set the cook time for the food you are trying to heat or cook. Enter the time you wish to cook and press enter/start (EX: 7mins and 30 secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This feature is to add time to the cooking time only in ten second intervals. If you want to add time without restarting press this button to add ten seconds each time it is pressed.
Less: This is used to decrease the cooking time by ten second intervals. If you want to decrease time without restarting the time press this to decrease cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This is use to choose the power level in which to cook or heat food or beverages. To change the default setting of 100%, press the power level button and press the level you desire, if you desire only 50% then press power level the 5 and enter/start. Hint: Change the Power level before entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This controls the light on the bottom of the unit if you have a mounted range above your stove or under your top counter cabinets.
Hot Water: This is used to heat water for beverages such as coffee and hot chocolate. Use Extreme caution when removing baverages from your unit, they will be hot and could cause injury.
Popcorn: This is used to pop popping corn, when placing the popcorn in the microwave press the this feature and enter/start and it will automatically start the correct time for cooking. This feature is designed for the individual packaged popcorn use. Do not place any foil or loose popcorn in the unit this could cause damage or injury.
Kids Meals: This is used to REHEAT meals for children it works at a lower power level. This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not place any metal objects or objects than can melt this can cause damage or injury.
Warm Hold: This is to keep foods or drinks warm for any length of time up to 99 minutes and 99 seconds. Although it is not a recommended to run a unit at the maxium time limit.
Melt: This is used to melt butter, margarine, chocolate, cheese and marshmallows. Do not leave these items unattended during the duration of melting time to prevent any unwanted over heating.
Soften: This is used to soften ice cream, butter, cream cheese, and frozen drinks. Do not place anything in a container that is made of foam or metal this can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This is the handle or button on the front of the unit to open the unit after the unit is done cooking or in use. Do not open the door during the use, always press the Stop/Clear button first. Also do not remove hot items without oven mits or waiting time food is at a safe handling temperature.
I have a JVM1850 1100 watts. It's not heating. Shortly after we got it I think a fuse blew because we always had to turn the vent on and then the cooking time which worked. Now, it stopped heating all...
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacturer and model. Parts are available at any of the following webistes: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites include illustrated parts listings that can help you locate and properly identify any parts you may need. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 47 in the parts listing (part number WB27X10388). This microwave oven is also equipped with various thermostats that (if blown) can cause similar symptoms to that of a blown line fuse. So, if the line fuse is NOT blown, you may want to check all the thermostats to see if they are still good. You will need to remove each one and measure across the terminals with a multimeter. A good reading is 0 ohms. NOTE: The various thermostats are listed as items 27, 61, 74, and 77 in the parts illustration. The thermostats typically will trip if the oven cavity has been overheated. Cooking items that are high heat producers such as popcorn or baked potatoes in rapid succession can often cause this problem. Allowing the oven cavity to cool a few minutes with the door open between cooking can prevent this from occurring.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
2helpful
3answers
It just quit while cooking. Is there afuse in this microwave?
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line fuse is listed as item 12.
You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
3helpful
Microwave has power, but wont cook.
Good Morning,
Sounds like it is not heating up. First, check the unit for a blown fuse, if the fuse is good then the Magnatron tube is bad. Let me know if this helps and thank you for using FixYa!
My jvm1190 reads F4 when we try to use auto functiions
There is a fuse blown, but I can't explain how to replace it. They are inside the unit. Good microwaves have many fuses and can be powered up, but have a blown element fuse.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
