Question about Gestetner DSm618 All-In-One Printer
Gestetner 3225 When we start the machine it gives us a error SC401. Please help
  • Anonymous Nov 18, 2008
    sc546 ????????????
  • Anonymous Jan 21, 2009
    السلام عليكم
    تخرج في الشاشة سبانة هل من الممكن مساعدتي في فرمتة الجهاز شكورين
  • 37 Answers
SC401: Transfer roller leak error 1
SC402: Transfer roller leak error 2
-Definition- [B]
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
· High voltage supply board defective
· Poor connection of the PCU
· Transfer/separation unit set incorrectly
Posted on Aug 14, 2008
Error codes sc401
try changing the transfer or cleaning it very well
Dec 03, 2013 | Gestetner DSc460 Copier
The canon ir 3225 gives me error e 000280 - 000 code please assist
i have the cannon ir 3225 and i use id management & pasword but i forgot the management id and pasword...how to riset pasword and solve the problem
Sep 06, 2011 | Canon imageRUNNER 3225 Black and White...
Gestetner 6123cp gives E-06 error. Can you help me?
Gestetner cp 6123p+ shows E-06 error.
please i need your help ?
Apr 08, 2011 | Gestetner P7527 Laser Printer
Error sc 321 @ Gas. 3225 photocopier
What is the brand? If it is a Ricoh/Gestetner product, the SC321 is a bad Laser Diode unit. Quite expensive but also obsolete.
Mar 09, 2011 | Office Equipment & Supplies
Wha tis the error code sc401 in ricoh 2400 plotter
there could be following three possibilities
SC401 Transfer Output Abnormal SC401- Transfer Roller Leak Detected SC401- Transfer Roller Leak
for more detail click http://www.smilecopy.com/download/greske.pdf
hope it helps
if so, do rate the solution
Nov 28, 2010 | Ricoh Office Equipment & Supplies
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Gestetner Copier
My Rico Aficio 200
Please open the front door and turn the blue lever in the middle,
remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
If SC401 re-occurs, please check the Photoconductor unit (drum).
Aug 27, 2008 | Ricoh Aficio 180 Laser Printer
Gestetner 3225
Ax060267,This is the part number of the polygon mirror motor , it is worn out , your machine propably makes a high reving noise aswell when it starts to print , you can go to your nearest rico or gestetner outlet and get a new motor , it sits right in the middle of the machine , sometomes it helps to remove the motor and oil it with a very thin oil , but in mostcases it is beond repair .
Oct 24, 2007 | Gestetner DSm618 All-In-One Printer
Gestetner DSm618 All-In-One Printer Logo
355 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
