Question about Xerox Office Equipment & Supplies
How do you turn on a Xerox 7232 copier that is asleep on power save?
    President:
  • 2,072 Answers
You should just be able to press any key. You can go into the customer programs and set the sleep mode to 4 hours before going into sleep mode.
If the machine has been idle for more than 4 hours, it will physically turn the machine off, I will look up the adjustment and post it back to you here in a couple of minutes.
Posted on Jul 23, 2008
  • Rick Kasper Jul 23, 2008
    Here is how to modify power save and sleep mode.
    The Power Saver feature can be used to significantly reduce power consumption during inactivity.
    NOTE: There is a Power Saver button located on the upper, right of the Control Panel that lights-up when the Power Saver feature is enabled.
    The Power Saver feature operates in the following modes:
    • Low Power Mode: The machine automatically switches to the Low Power Mode after a certain period of time from the last copy, fax, scan, or print operation. In this mode, the Touch Screen is turned off and the Power Saver light is on. The Low Power Mode is canceled when the Power Saver button on the Control Panel is pressed, or a fax or print job is received by the machine. By default, the machine will enter the Low Power Mode after 15 minutes of inactivity. The default setting can be modified within the range of 1 to 240 minutes.
    • Sleep Mode: The machine automatically switches to the Sleep Mode after the Low Power Mode continues for a certain period of time. The Sleep Mode has a reduced power consumption compared to Low Power Mode. In this mode, the Touch Screen is turned off and the Power Saver light is on. The Sleep Mode is canceled when the Power Saver button is pressed, or a fax or print job is received by the machine. By default, the machine will enter the Sleep Mode 60 minutes after the machine enters the Low Power Save Mode. The default setting can be modified within the range of 1 to 240 minutes.
    To modify the Power Saver modes:
    NOTE: You must be a System Administrator to perform this solution.
    1. Login to the System Administrator mode. See the Related Items below for additional information.
    2. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Touch Screen.
    3. Select the [Tools] tab.
    4. Select the [System Settings] button.
    5. Select the [Common Service Settings] option under the Group section.
    6. Select the [Machine Clock / Timers] option from the Features menu.
    7. Select the [Auto Power Saver] option, and then select the [Change Settings] button. The Auto Power Saver screen will be displayed.
    8. Use the [Up] or [Down] arrow buttons to select a value between 1 and 240 in the Low Power Mode section.
    9. Use the [Up] or [Down] arrow buttons to select a value between 1 and 240 in the Sleep Mode section.
      NOTE: The value of the Sleep Mode must be higher than the value entered for the Low Power Mode.
    10. Select the [Save] button.
    11. Select the [Close] button three times and wait several seconds for the Auto Clear service to logout.
    To log in the code is either 1111 or 11111. Either four or five number 1.
    What isn't working ? Is there something else wrong?
How can i resolve error 010-333 for xerox 7232
Fuser unit change problem continue nvm change 744-004 change value 0
Feb 09, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
I need to know if the Transfer Belt Unit for the XEROX 7232 (newer model) PN 064K92790/1 can be used in the 7132 (older model) instead of the # 064K92402/4. I have one and would really not have to purchase...
What you have is a 7232 IBT belt assembly. The internal workings of the assembly work with the 7232 and 7242, but not the 7132 - they are different model series.
Aug 28, 2009 | Xerox Office Equipment & Supplies
Xerox 7232 workcentere cannot send emails
Judging from what you've said, I would say this is a setting on the printer. You need to make sure you have the outgoing address correct. Basically go into your printer settings with your E-mail server IP's.
Jul 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Mar 20, 2009 | Xerox Office Equipment & Supplies
322 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
