Question about Lexmark T520 Laser Printer
T520 Printer - slew of issues.
The printer jams every 4 or 5 pages which I thought was a sensor or roller issue. But cleaning has not helped. I also noted heat scoring on the bottom of the panel above the fuser and on the inside of the duplexer. The whole printer gets ridiculously hot when it prints as well. Should I continue to focus on cleaning, etc or could these jams be indicative of a larger problem. If so, where should I look next?
  • 1,056 Answers
Replace the fuser. These are the same as a Dell 5200 printer, and a fairly common problem.
Posted on Jul 23, 2008
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Paper Jam error
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure thatyou have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
May 17, 2008 | Olympus P-440 Thermal Photo Printer
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
OKI C9600 paper jam problems: Paper jams continually, either on first attempt to printing or if it prints a page the 2nd page inevitably jams. Printer has only done 1500 pages since new ,and i have removed...
Wow! That's quite the printer you have there. The C9600 does have a feed roller in the front; and it's not uncommon for paper to still get stuck. Does your paper "fan" when it goes through; or simply, go through and jam? It's possible a paper feed sensor is bad too. Another thing you might want to check is the paper tray; and that the paper is set to the proper size.
Also be aware, the OKI 9600 had a recall a year or so ago for some potential "shock issues" I would advise you to check with OKI directly to determine if this printer is part of that issue too.
Jan 04, 2011 | Office Equipment & Supplies
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual: Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | HP LaserJet 4 plus Printer
My lexmark t520 wont print it says paper jam but there isn't one?
Hi Melissa:
I think that you problem is feed rollers. If you take the paper tray out and look inside you will see two white rubber paper feed rollers. If you feel them and they are smooth,then they need to be replaced. They should feel ruff.
Jan 09, 2009 | Lexmark T520 Laser Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Re: Paper Jam
most likely something jammed down deep, or the rollers need cleaning..
Mar 28, 2008 | Lexmark T520 Laser Printer
Lexmark T520 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
