These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
To connect to the internet using GPRS/3G, open the All Programs screen and then tap Settings > Wireless controls > Mobile network settings. To setup an access point automatically, tap the switch beside the Automatic setup option to turn it on. To create a new access point, tap Access Point Names. Press the MENU button and then tap New. Enter the access point details and then tap Save.
NOTE 1: An internet connection (GPRS/3G, etc.) is required to access this service. Your operator may charge for using GPRS/3G.
NOTE 2: To open the All Programs screen, please see the FAQ "How do I open the All Programs screen?"
NOTE 3: Contact your mobile operator to get the settings for your carrier, if needed
Don't know the solution....but am having the same exact problem! LCD screen just showing static-like jumpy lines. Must be a wire connection I guess but when put in docking station and turned on, computer still doesn't see it as can't access the menu on lcd screen -- can't see it! Help! Just, hopefully, recorded my 19 mth old son's first time in the snow!
go to the start menu and key on the program lower tab. The go to accessories. Click on command prompt which takes you to the DOS screen.
Now you will see a blinking cursor on the black screen which all you need to do is to type in chkdsk /f /r
This will repair any programs that were not running correctly. after it is done your computer may reboot itself. If not reboot it and see what it does, Itshould work fine unless deeper problems in the EXE BATCH FILE is present
You can scan down through the list of programs that start up when you boot your computer. Many of the programs you install or download and allow to install place a start up line in your start up programswithout your knowledge.
Over time, you are starting up lots of programs you can access after the machine is started. When you find one you don't want to start up, you can click it and at the right hand bottom of the screen you can remove it from the start up list, or delete it completely if it is something you do not want on your computer.
Refresh, reboot, and see if you notice a difference.
This may be because your monitor is not connected to your PC or has a faulty connection -make sure the screws at the back of your computer are fully screwed in
1) These Apex players can handle multiple sytems (NTSC/PAL) Is it possible it is switched in the wrong mode?
Follow the jumpy picture and enter the menu to see if it is switched in the PAL mode (You may have to follow the user manual and try to look at the screen carefully while following to menu flow)..
Some APEX units have a button on the remote to switch the systems.
2) I have also seen some TV's that will not handle the progressive scan mode... Try switching in the menus.
(1) LAST USED APPLICATION
Enable password protection. Start>Settings>Password
(2) SENSITIVITY / PRIVACY
Choosing "Private" prevents the appointment from appearing on your Today screen. I figured this out by creating two appointments for today and making one normal and one private. The private appointment is still viewable in the Calendar application, so if you want to prevent others from being able to access this, enable password protection.
(3) TODAY MENU
There is no way to do this using the software that came with the iPAQ. However, there may be third-party software that would accomplish it. I did a quick search that turned up nothing, but you might be able to find something. Try handango.com or pocketgear.com.
