Question about Toshiba Computers & Internet
Display connection is loose. Display comes and goes as you change the angle of the display. How do I access the connector to reseat it? Satellite P205-S6287.
    Problem Solver:
  • 8 Answers
How old is the computer? Have you checked Toshiba's website for information?
Posted on Jul 23, 2008
We have a Compaq CQ60 laptop with display issues. Display only works at certain angles. Moving toward open or closed causes loss of horizontal sync. Screen is still bright. External display is unaffected...
you may have a bad inverter of bad inverter connector....or the connector is loose.. this can cause perminant damage if left untreated. most likely you may have a loose connection,,are you under warranty?
Dec 02, 2010 | Compaq Presario CQ60-220US PC Laptop
When i plus up my laptop the power lights come on but it doesnt post or screen comes on.
Check the hard drive activity light; if it is active at power on, look at the display from an angle to see if some ghosting of images is visible. If so, the back light for the display or its inverter may have failed.
If you have a friend you can borrow a monitor from or use briefly, connect it to the VGA (D-15 connector) to see if you have any video output. If you still see nothing, turn off the power and access the memory in the laptop. Remove and return any memory cards and try it again.
If you still have no boot, it will need technical help since this could indicate a failed motherboard or CPU.
Nov 15, 2010 | Toshiba Satellite L455DS5976 Notebook
Wen i conect my compuer only de power light comes on.day before i working normal and i switch off normal.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Toshiba Satellite 1805-S204 Notebook
I have a Toshiba Satellite A15-s219 that someone gave me,and it does lite up. I think it might be the adapter,because it does warm up when plugged in to a wall outlet. Should I be looking for something...
Aug 20, 2010 | Toshiba Satellite A15-S129 Notebook
LCD Display problem
From your description it sound like you have a faulty video cable or the video connector on the motherboard is loose.
Reseat the connector and it may solve your problem.
Jul 13, 2009 | IBM Computers & Internet
Display does not function
Try to clean its memory card or reseat it. You can use clean soft eraser to clean its edge connector. Do this when you first disconnect battery, off, and no other power source is connected to your unit.
This is the first step, then if still nothing check your hard drive and cdrom reseat if needed.
Jun 16, 2009 | Toshiba Satellite A135-S4527 Notebook
If I open my Satellite A105 display too far, it goes black.
Hi, This is definitely a loose connection problem.
Does the screen go completely black or just a part ?
If its just a part, LCD is defective. You may have to change the whole LCD screen. You can get one for ~180$ from ebay
If the whole is turning off, I guess the power cable might be little loose.
You can open the LCD panel and check if you know what you are doing.
Else take it to a normal technician and ask him to open the LCD panel and see it.
Nov 17, 2008 | Toshiba Satellite A135-S2276 Notebook
The screen is blank
Before you go out and buy a new laptop, you might want to consider this. The problem, as described would indicate that you may have a LCD cable connector that is loose. To check this out, you will need to access the motherboard to reseat that end of the cable and access the inside of the LCD to reseat the other end. If this doesn't work, you might want to try replacing the LCD cable itself.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating.
Thanks you, and have a super day!
Ron-
Nov 12, 2007 | Compaq Evo N1020V Notebook
Screen
If you have access to an external monitor, you might want to hook that up to your laptop and try it. If the display looks good on the external monitor (which I would suspect that it will) then, you may have a loose LCD cable, a worn cable or a bad LCD display. Try reseating the connector. With the LCD cover off & power on, carefully wiggle and flex the cable and see if there is any change in the display. If not, your LCD display is probably going bad on you.
Hope the rest of your day goes better!
R-
Nov 02, 2007 | Acer Aspire 3000 Notebook
Notebook lcd screen flickers and goes white
The refresh rate may cause this problem sometimes...
Try this
Right-click anywhere on desktop->Properties->settings tab->advanced button->monitor tab->screen refresh rate drop down list..Chose the refresh rate at which the screen will not flicker(try em' one by one)
If it doesn't work please post a comment and await reply before rating...
Oct 19, 2007 | Audio Players & Recorders
Computers & Internet Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
