Question about HP LaserJet 4250n Printer
Duplex printing hp laserjet 4250n
If tray runs out of paper while printing a document that is to print duplex, the printer hangs and must be powered up again. The print document is then lost. how can i correct this.
Thanks
  • rosefontaine Oct 30, 2008
    The problem was not corrected after updating the firmware. Thank you
  • rosefontaine Nov 07, 2008
    Total ram memory is 80 mb. It appears as though when tray 3 is empty and a report that calls for duplex printing is run the printer hangs.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Please upgrade the firmware of the printer:
1. Download the firmware file from the following website and extract it.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&prodNameId=412158&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25065-13
Expecting that the printer is connected over the network:
Remote firmware update by using FTP through a browser
Complete the following steps to update the product firmware by using file transfer protocol (FTP) through a browser.
NOTE: The following instructions can be used on Windows or Macintosh operating systems.
Take note of the TCP/IP address on the EIO-Jetdirect page. The EIO-Jetdirect page is the second page of the configuration page printout.
Open a browser window.
In the address line of the browser, type ftp://<IPADDRESS>, where <IPADDRESS> is the TCP/IP address of the product. For example, if the TCP/IP address is 192.168.0.90, type FTP://192.168.0.90.
Locate the downloaded .RFU file for the product.
Drag and drop the .RFU file onto the PORT1 icon in the browser window.
NOTE: The product automatically restarts the firmware to activate the update. At the end of the update process, the Ready message appears on the control panel.
The following describes how to upgrade firmware in the LaserJet 2400, P3005 and 5200 Series Printers using a USB connection only.
To send the firmware upgrade via USB, you will need to know the name of the computer the printer is connected to, and the printer will need to be shared.
To find out the name of your computer:
Click the Start button, Programs, Accessories, System Tools, then choose System Information.
You will find your computer’s name in the right window-pane next to System Name.
Write down this name as it will be needed later.
To share the connected printer:
Click the Start button, Settings , then choose Printers ("Printers and Faxes" on WinXP).
Right click on the printer you need to send the upgrade to and then choose Sharing.
On WinXP, if you encounter the following link "If you understand the security risks but want to share printers without running the wizard, click here.", click the link.
Select "Just enable printer sharing" and click OK .
Select Shared As: ("Share this printer" on WinXP) and type a name for the share.
Click Apply and write down the share name as it will be needed later.
To send the firmware upgrade using a USB connection:
Go to a DOS Command Prompt and locate the directory where you saved the firmware file. (To open a Command Prompt inWindows 2000 or XP, go to the Start button, then choose run, then type CMD and hit Enter, in Windows 98 or ME, go to the Start button, Programs, Accessories, then choose MSDOS Prompt). This will bring up a small black screen as displayed below:
If connected to a USB port, Type: copy /b filename \computer nameshare name (for example, copy /b ozfw.rfu \computer1printer).
Press ENTER .
The control panel displays receiving upgrade followed by performing upgrade . The download may take several minutes.
The control panel displays processing job .
The download is complete when the printer reboots and "READY" message is displayed on the control panel.
Posted on Oct 30, 2008
  • Nikhil Gedam
    Nikhil Gedam Nov 07, 2008
    Please let me know what is the size of the memory. Minimum should be 80 MB.
    Please confirm
  • Nikhil Gedam
    Nikhil Gedam Nov 10, 2008
    If the printer hangs after running duplex printing, please right click on the driver, select Device Setting tab, then increase the printer memory (at the bottom under this tab) to 96 MB.
    Also Then click on Advance tab and select the radio button, Print Directly to the Printer.
    Let me know the next update.
    - Nikhil
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 17, 2012 | HP LaserJet 2420 Printer
Why printer 4515 this error MANUALLY FEED OUTPUT STACK for duplex pritnting
HP P4515n is not a duplex printer by default. It is a network printer. ('n' suggests it is a network printer. Duplex printers have 'd' in the model number).
If you want to print both sides, manually feed sheet by sheet. Or else you can do the following:
If you are using, say MS Word, print only the odd pages (Print the normal way. No need to manually feed paper). Then arrange the printed papers in the proper order and keep the printed side as back side. Insert the set of papers in the printer and print only the even pages.
First print a document of about 6 pages to get the hang of it.
May 12, 2011 | HP P4515n LaserJet Printer
Hi there! Printer: HP Laserjet 4100 Problem: does not want to make both side printing. Used settings: Printer Properties-&gt;Finishing-&gt;Print on Both Sides (click) Thanks for your...
To automatically duplex, you need the optional duplexing mechanism.
If you don't have this, your only option is to print the odd pages first, put the papers back in the tray, then print the even pages.
When you put the pages back into the paper tray, make sure they are print side up.
Try with a 5 or 6 page document first to be sure you get the orientation right.
If you HAVE the optional duplexing unit (which sticks out the front just above the main paper tray) then post a reply here and I'll try to help you further.
99% of the people that own this unit do NOT have the optional duplexer!
Mar 12, 2011 | HP LaserJet 4100 Printer
My HP LaserJet 4250 is printing my document margins off even when centered in Word?
check the tray amargin, or the paper sizeselected in your printer setting
Mar 22, 2010 | HP LaserJet 4250n Printer
Im trying to print a document in word thats about 200 pages and i just want to print only 4 of them and whn i print it says it prints in the box but nothing comes out the printer but when i try another...
Alrite now, firstly, since you need only 4 pages of the 200pg document, go to File > Print > Select page range (e.g. 1-4, 51-54, etc)
Then print and make sure you have pages loaded in tray 1.
You can also have papers in tray 2. If MS Word does not respond, then change the drivers to UPD (http://www.hp.com/go/upd), the system may have legacy drivers or An earlier version of firmware.
Rgds,
Nikhil
Sep 11, 2009 | HP LaserJet 4250n Printer
How to enable duplex printing in hp laserjet 4250
This unit needs to have a duplex unit installed if you want to duplex. If the back of the unit is "flat" you do not have a duplexer installed.
the duplex unit slides into the back of the printer between the back door and the paper tray. when installed you will have a bulge on the back of the printer about 7 inches tall and the width of the printer that sticks out about 5 inches.
after installing the dupelxer you may need to enable it in the print driver under properties then the advanced tab you should see a spot for advanced settings.
Jun 07, 2009 | HP LaserJet 4250n Printer
Laserjet 4250 not dupexing
Had this same issue on my 4250dtn. The solution in my case was that both paper trays were set to "custom". This is a small lever on the right side toward the back of the paper tray. Even HP was stumped on this. Hope this helps.
Apr 01, 2008 | HP LaserJet 4250n Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
How set Printer to Autoselect Tray
This will most likely be the in the menu on the printer. Refer to the users manual and how to access those setting.
Jan 26, 2007 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
583 people viewed this question
Ben Johnson
