Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
I need a photo of the insode of a incanto, i have disconnected the HV cables and not sure which way they go one.
  • KaffeSumpen May 11, 2010
    a sry saw that it is in the Sirius catagory, so just clarify the HV name thing, and i will help you
    First a Incanto can look very diffrent from machine to machine.
    What kind of Incanto is it that you have exactly?
    Not sure what you mean by HV either please clarify.
It's ok problem fixed. i removed all the high voltage cables on the left hand side of the board, and it took me a few goes to work it out, however the problem i had is now fixed and the machine is working fine.
Posted on Jul 25, 2008
P3000 and 3004
its a prius. take it in,
lost of things to go wrong with any hybrid, due to huge complexity.
if serious DIY, and feel compelled to get shocked on HV?
then read the FSM buy it ran read all the pages on 3000
and on how not to get shocked and killed. do so , dont guess
study the book.
or go there, first google hit for 3000, read this ?
http://priuschat.com/threads/code-p3000.49355/
could it not just be, that you didnt follow the battery swap instructions
in the FSM then trip these/
reset them and see if they come back.
P3004 - Power Cable Malfunction 130 HV Battery Malfunction. When HV battery voltage becomes lower than inverter voltage
131 Power Cable Malfunction. When main fuse is blown out, service plug is disconnected or limiter resistance is cut off
133 HV Battery Malfunction. When inverter voltage sensor is malfunctioning or limiter resistance value increases
Feb 03, 2014 | 2002 Toyota Prius
What type of power cable is required for P915. thank you. I just have a USB.
Lexmark P915 requires 25 Watt HV Adapter (220 - 240V AC, 50/60 Hz) in HV countries OR
25 Watt LV Adapter (100 - 127V AC, 50/60 Hz) in LV countries.
So, you have to buy a power supply as per above specification.
In case the cable marked at '2' above is missing, you can find/ use a similar cable, which can be purchased from a local computer store.
Lexmark P915 Setup Guide
Hope it helps! Good Luck!
CreativeTECH
May 10, 2011 | Lexmark P915 InkJet Photo Printer
How to drain coffee machine saeco s-class incanto classic
Subject: How to drain boiler of Saeco Incanto Deluxe
I got an answer from Saeco Customer Service as follows:
Good Afternoon,
All you need to do is have the machine turned on and up to temperature. Make sure that you have a full tank of water as well. Make sure the machine is set for hot water, then turn the knob on the side of the machine to start water flow. Once the water is flowing out, remove the water tank and, leaving the knob turned open so that the water that's in the system drains out. Once water stops coming out, close the knob and shut the machine off.
The water is now drained from the system.
Thank You,
Customer Service
Saeco USA
800-933-7876
Feb 23, 2010 | Saeco Incanto Classic Espresso Machine
My epson stylus photo R300 is not printing because it says device is not connected, am i missing a cable? the usb cable is connected and so is the power cable... do i need the one that says preview monitor...
You only need the 2 cables you've mentioned Try Disconnecting the printer from the PC and re installing the drivers Don't reconnect the printer until told to during driver install make sure it is turned on.
Jul 29, 2009 | Epson Office Equipment & Supplies
Dell W1700 picture went out. Still have audio.
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
Nov 29, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Need parts for Incanto S-class (door unit)
Go to this site and find a Saeco Service Center near you.
http://www.saeco.com/countrygate/
There are two number on this spare part if it is the spare part in the machine, if it is that on the door you only have one number.
Best regards
/Mirran
Nov 08, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Can a d board on a sony kp53hs30 be replaced at home? If so how is it done?
yes just label any wires you disconnect then remove the screws holding the circuit board in (six screws) then remove the board very easy the hardest is getting the HV cable out of the splitter but it will come out with pliers twisting it 90 degrees put tape on the plkiers so you dont hurt the HV cable ( Large red wire)
Jun 30, 2008 | Televison & Video
Incanto deluxe is leaking
sometimes the spout in the door is kinda clogged. Take this out ) need phillips head) and clean it . Make sure to turn the knob on it to left and right while cleaning.
There is no gasket but the little plastic pipe goes in there.
Should help.
Check this for parts SAECO
Jun 01, 2008 | Saeco Incanto Classic Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
61 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
