Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Playing eve im trying to put 2 computers on a belkin wireless g router to play a game called eve online but the router will not even let me play eve on one computer
  • jposton Aug 10, 2008
    can I set the router program to stop dropping connection to Cod 4 when I use the router. Works fine modem to pc but the router is pits.I am using ethernet to eternet cable not wireless.I have need to use 2 or more pc at the time. Maybe have to upgrade routers???
    Master:
  • 363 Answers
If you want to know more things about RSGold can go to this website www.rsgoldfast.com
Our service is the most professional and most secure and convenient
Posted on Oct 22, 2016
    Problem Solver:
  • 13 Answers
Under System Settings on the Router: Extend the time of the "Time Out" or inactivity under NAT or, if that option is not available, then turn NAT off.
Posted on Aug 17, 2008
Sup. i have a belkin n1 router.. and i play world of warcraft.. at the moment im not runing wireless.. a am only using it for a conection to my main pc of the house. and almost every hour on the hour i get...
Well fer a start you should'nt be sitting round al day playing games. Maybe gitcher but off the sofa and mow the lawn like you said you were gunna do last week.
Jan 10, 2018 | Belkin N1 Vision Wireless Router
How to change the nat settings on my belkin play router from strict to open so i can play the ps3 online gameplay more easily.
what about to set the ps3 ip address on the DMZ for the router that will give all the ports open to that address and will play freely
try go to advance settings and firewall or game and applications there is where you will set dmz application .
Good luck
Jul 28, 2010 | Belkin (F5D8231-4) Wireless Router...
I can't play my PS3 & Comp. at the same time with my router
try assigning a static IP address in the range of belkin router for your computer and PS3...that is 192.168.2.X (where X = 2 to 254)
the default gateway should be 192.168.2.1.... Log into your router and enable DMZ for the IP address assigned to your PS3...Goto Virtual servers in the router setup page and open the concerned ports for playing games in your computer(enter computer IP here in virtual servers)....the common gaming ports would be,
port 80 TCP,UDP
port 88 TCP,UDP
port 3074 TCP,UDP
port 53 TCP,UDP
click apply changes and try playing now... you can also restart the router for working better.... enjoy....
Mar 09, 2010 | Belkin F5D7234-4 Router
My belking keeps losing connection during games?
If your wireless you probably need to change broadcast channels on the router ( to the last channel) if its hard wired, you probably need to port forward the ip address for the Xbox
Oct 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have a Belkin Wireless router and I have a PS3
Actually you don't need to forward ports when playing online games. The router should automatically locate the ports for the game because it has UPnP function. Here's what you can do. Disable the port forwarding and DMZ that you set on the router. Look for the UPnP function of the router and disable, Save it. Enable it again, then save. Now power cycle your router. If you have Static IP on the PS3 network settings, try to set it first to automatic IP and automatic DNS.
Hope that helps.
Sep 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Dropping Connection
All the LED except power should be flashing, that indicates traffic flow, power should be steady.
If all wired and wireless connections fail it is unlikely the router, more likely the cable/adsl modem that is dropping connection. Test by connecting a pc directly to the cable modem, watch for dropouts. If fails, contact your ISP service dept for line check and do a cable speed check from an online source.
Check also terms of service for the package you bought, many low end services restrict speeds below dialup if you go over your transfer limit. Multiple pcs playing online games use a lot of bandwidth. the speed restriction may put you below the threshhold for game server
Jun 08, 2008 | Belkin (F5D5231-4) Router
Connecting online Madden 08 ps2
I experienced the same problem. I have the ps2 slim. The problem was so bad that i had the slim for about 3 years and still could not play any ea games online. About 2 months ago i finally got it to work though, allowing me to play madden ncaa and many other sports games from ea. I also have dsl broadband just like you. I do not have a router though. I just hooked my ethernet cord straight into the back on the ps2, my computer is really close by. I would reccomend a router though.
Enough of this bs though. Now solving the problem. There was actually a firewall keeping me from connecting to ea servers. Which in turn meant no ea account and no ea play online. Go onto your computer and turn your FIREWALLS OFF. This still may not work though. I done this and an unknown firewall was still blocking it. THERE WAS A FIREWALL IN MY MODEM.
CALL UP YOUR INTERNET SERVICE PEOPLE AND TELL THEM TO TAKE THE ******* THING OFF SO U CAN ******* PLAY. I ALSO FOUND THAT LIMEWIRE WOULD NOW WORK ON MY COMPUTER AS WELL.
By doing this you will open peer to peer connections with other programs and players online.
Nov 10, 2007 | Sony PlayStation 2 Slimline Console
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
180 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
