Question about Intel Motherboard
System shutdown when I start the system. it boot when I out in the bios the system will shutdown.
  • Madhav Suresh May 11, 2010
    Could you give more details to your problem?
  • Mike Peluso
    Mike Peluso May 11, 2010
    More information is needed. You're statment is confusing. I am unsure what you're problem might be. Please try explaining you're issue again.
    This is what I think you are saying. You boot you're system & enter the bios. once in the bios you're system will shut down?
    Answer these questions. Do you hear any beeps when the system boots? If so how many. Do the beeps conitnue in a loop? Are the beeps long & or short & do they repeat?
    Please include the model number of the Intel board? Some common reasons for a system to shut down can be caused by the CPU fan not running or running fast enough whick will cause the system to shut down because of overheating. Loose data cable's or loose power cables. A virus infection. Bios file coruption, weak bios battery.
    Mike
    President:
  • 2,351 Answers
Systems that shut down after being powered on can point to an over heating of the CPU. Other factors come into play with overheating. Too much dust build-up on & under the CPU fan blades. Dust builds up in-between the heatsink fins (Thus the CPU fan can not cool the CPU chip.)
The CPU fan may be running too slow. When the PC system shuts down it’s saving you from hurting the system. You did not list the model number of you're system. Check you're system & clean the mentioned parts. Use canned air & a dry clean small paint brush to help remove possible dust buildup blow the dust away with the canned air.
Mike
Posted on Jul 26, 2008
System boots up and then within 5 minutes shuts down dead
Hi! Welcome to Fixya.
Have you try booting to BIOS and wait if it will still shutdown? Going to BIOS requires you to press F1 or DEL (or other keys depending on manufacturer) If it will not then try Safe Mode (F8) and check if it will still shutdown.
If the system will still not turn off, then you may try re-installing Windows or run stress test that will utilize the system and force it to shutdown. If it did then it may be the motherboard or other parts that needs to be replaced. If you are lucky (that computer did not shutdown) and able to re-install windows that the end of your problem. but if you are still having the same problem then possibly your computers motherboard may have a leaked capacitor or some sort.
Hope this instruction is a great help. Thank you for contacting Fixya. Bye for now.
Aug 27, 2011 | Shuttle XPC PC Desktop
Tip
Speed Up Windows XP Boot and Shutdown Times
This guide will show you how to shorten the time it takes for your desktop to appear when you turn your computer, and make it shut down faster as well. Here are a few tips to get you right to your desktop as quickly as possible after startup.
To speed up Windows XP shutdown times:
Turn off services that you don’t need. If you want XP to shutdown faster, you need to have less services running for it to shutdown. Disable any unneeded services.
Don’t clear virtual memory at shutdown. Clearing the page file can provide more security, but that comes at the expense of speed. I don’t really care if someone can look at my page file. If you are more concerned with the shutdown speed, then you will want to disable this option in the registry. You will need to locate the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management registry key and change the ClearPageFileAtShutdown to 0.
To speed up Windows XP Startup times:
Waiting for your computer to boot can be a painful process. Though Microsoft has taken steps to speed up the boot process, it still can be improved. Here a few suggestions you can follow to speed up your Windows XP boot time.
Boot Defrag. If your boot files are closer together it will take less time for your hard drive to seek the files, therefore giving you a faster boot time. This was enabled by default on my machine, but you will want to make sure you have the option enabled in the registry. In HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction
You will want to set “enable” to “Y”.
Keep the registry clean. Windows registry can be a disaster. When programs install they will create registry keys. When you uninstall the program it will leave behind useless registry keys. The solution is to use a good, reliable, registry cleaner. Be careful in which one you choose though because a bad cleaner could really screw up your system. My favorite choice is CClceaner, which will also rid your machine of some spyware and temporary internet files. You can download it here.
Change BIOS Settings. The computer has to go through the BIOS before actually touching Windows. Changing a few settings can decrease the time it takes to actually get to the Windows XP boot screen. First you will want to run a Quick POST (power on self test) if your bios has this option. Secondly you will want to disable booting from a floppy (especially slow), cd, usb. If the BIOS only has to look for the hard drive it will go much faster. You will want to remember that you changed this setting though, incase you have to boot from one of these devices for troubleshooting. The last option is to turn off Boot Delay if you BIOS has this available.
01011010 G.I.G hacker 0100101
www.gighacker.blogspot.com
on Feb 14, 2010 | Computers & Internet
Windows shutdown and won't start again
If the system doesn't start even enough to access the BIOS then it's a hardware fault, take it to a shop.
If you can access the BIOS then change the boot order and boot from a Linux Live-CD like http://pclinuxos.com/  , recover all your files and reinstall. Once the reinstall is over check the hard disk using HDTune.
Mar 28, 2010 | Acer Aspire One PC Notebook
Toshiba Satellite A45-S130 boot failure
* If it's a BIOS problem, try this :
1. Shutdown ur system, and remove the BIOS battery.
2. Reinstall it and start again.
3. You can also replace the battery. (if above steps don't works!)
4. Try to get a updated version of BIOS driver. (if above steps don't works!)
* If u r also hearing any kind of beep sounds, it may be bad RAM (memory). Try this :
1. Shutdown ur system, and remove the RAM.
tell me if these steps don't work! :)
Dec 31, 2009 | Toshiba Satellite A45-S250 Notebook
Boot sequence problem while booting
your mocs cell waltage goes down.
CMOS cell gives power to bios flash memory when it goes to low bios forgot settings after power off.
So purchase new CMOS cell it is on motherbord change it then save settings then it not forgot settings even after power off.
Thanks for using fixya.
Jul 27, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Toshiba Satellite M35 and BIOS/CPU Replacement
No the BIOS is not a replaceable chip. Yes the BIOS can be reflashed once the computer is working. And, definitely Yes. An overheated CPU will definitely cause a shutdown.
Mar 24, 2009 | Computers & Internet
Unable to shutdown NEC versa S3300
It assume to be problem with BIOS, check out the Bios Power Setting and Boot Priority, by pressing DEL, ESC or Function key usually used.
And change them and then try.
2 method - try after unplug external devices and found which one is conflicting due to which it going to automatically start when you shutdown.
Thanks,
Ellin
Nov 04, 2008 | Computers & Internet
Problem in reinstallins operating system
This can be started by changing the boot order of your system.
To do so, start up the laptop from a shutdown stance.
This part requires some speed, it will either require the "F2", or "F10" in most cases. IIts not 100% guarantee that this will be the two buttons required for activation of your bios.
WARNING: BE VERY CAREFUL IN THE BIOS. YOU CAN FOUL YOUR COMPUTER VERY EASILY BY CHANGING THE WRONG SETTINGS IN THE BIOS.
When you enter the bios, try to find the boot settings. And make sure your cd-rom is selected as the primary boot device.
After you change the cd-rom as the primary device, Save and Exit from the bios and your computer will automatically restart.
Make sure the O.S. (Operating System) CD is in the CD-ROM and it should automatically boot from the cd-rom, it may come up with options, your options should await you when or if the auto boot from cd works.
Hope this helps.
Oct 22, 2008 | Computers & Internet
Labtop will not start. A screen appears with three options; Diagnostic Screen, Boot Menu, and Bio Setup. it did not shutdown successfully and freezes.
Sounds like a problem with your hard disk drive either not functioning properly or not being seen by the system BIOS.
Have you reseated the hard drive?
Jul 27, 2008 | Fujitsu Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
