Question about ASUS P4SGX-MX Motherboard
VIA AC 97 Audio Chip set is not enable please enable it in BiOS In Bios audio is enabled and later i added the VIA Ac 97 Hardware through add hardware wizard but is says unable to start VIA Ac 97 "error 10 " and while i am trying to install driver from device manager while i give the path of driver which is stored in my hdd system is getting restarted . My Configuration are as follows Mother Board : Mercury Model KOB P4M266
  • 3 more comments
  • sujaybabuv Jul 24, 2008
    No it doesnt support
  • Anonymous Nov 16, 2008
  • Anonymous Nov 30, 2008
    im not new to the pc world so when i got this error i went into the bios and what do you know it was enabled??? wtf it still doesnt work!!!
  • laminsodiya Jan 13, 2009
    on my computer a windows xp it says i need to enable it in bios but i don't know how to??? help PLEASE!!!
  • Sergio Scalfaro
    Sergio Scalfaro May 11, 2010
    have your sistem dual boot?
    Guru:
  • 61 Answers
You can search your model board on the site and download and save your drivers to the pc or run them
http://www.driversdown.com/driverslist/s_479_2.shtml
Posted on Jul 24, 2008
Hi how are you
Posted on Nov 19, 2008
I purchased an ASROCK P4i45GV R5.0 motherboard. I have successfully installed Realtek HD audio driver R2.65 but not showing icon in task bar or Device manager. AC 97 audio is enabled in BIOS also. Please...
hi,most commonly the malfunctioning of your hardware is because of virus.try to scan first your PC.depending on what kind of anti virus do you have.
simplest way of scanning PC/hard disk.
open my computer right click your drive in which your system is installed click scan with (your anti virus)
Sep 23, 2011 | Computers & Internet
In my system real tek ac 97 is not working
Go for set up the Bios again.
Set enable onboard audio for *********** board.
Now Install the driver again.
For set up bios follow the bellow link.
Phoenix BIOS setup and help
http://www.computerhope.com/help/ami.htm#01
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
If the problem is same
Install usb audio .
http://www.amazon.com/Syba-SD-CM-UAUD-Adapter-C-Media-Chipset/dp/B001MSS6CS/ref=sr_1_1?ie=UTF8&qid=1298800911&sr=8-1
Hope this helps.
Feb 27, 2011 | Computers & Internet
My mother board is 82801 problem is no audio device
There could be a problem with the actual audio circuit (which is built in I believe, not sure) on the motherboard itself or the audio has been disabled in the Bios. Reboot your computer and access the bios software and check to see if it has been disabled. If so, enable it and save changes and exit. If not, the chip itself could be defective, you could simply buy a third party audio card and install it in an open slot on your motherboard.Follow the manufacturers installation instructions and Install the drivers that came with your card, (after booting up your OS), and that should take care of your problem. Good Luck!!
Jan 05, 2011 | Intel Motherboard
The audio support is disabled when i check the bios menu and i want to enable it but nothing i do seems to be working, i tried to install AC 97 wdm audio but it shows that some "rtlvaac" is missing the...
If the bios shows audio as disabled and you are unable to enable the audio in bios, you need to update the firmware of the motherboard. You can find the firmware on Intel website by searching with model number of motherboard.
May 30, 2010 | Intel Motherboard
There is no sound device installed on my computer
Mercury P4VM800M7
Check the Audio jumpers on the motherboard.
See page 1, (AUDIO1). There should be two jumpers over pins 9&10 and pins
5&6 for the rear audio ports to function. See pages 17 in you’re manual for a closer look.
Next check the bios. See pages 30 in you’re manual.
Bios, Audio setting should be set to [Enabled]. Save and exit the bios.
Open windows control panel than open Sound and Audio Devices icon.
Check the Audio tab and the Voice tab. Both should list as AC'97.
If not re-install you're audio software from the CD that came with you're MB.
OR you can download it from the link provided below;
http://download.cnet.com/Audio-Realtek-ALC655-AC-97-AUDIO/3000-2110_4-168843.html
If you still receive feed-back try another speaker system. (Still no change)? Audio controller is defective. Replace with a PCI sound card.
Cheers'
Mike
Apr 18, 2010 | Mercury P4VM800M7 Motherboard
BIOS of ECS L7VMM3 mobo..
You'll need to enter the bios menu. As soon as you hear a single beep press the Delete key on you're keyboard. See the top of page 27.
Open Advanced Chipset Features than find and open
VIA OnChip PCI Device, Page 39
Set VIA-3058 AC97 Audio to [Enable]. Save you're changes and exit the bios. When your system restarts you should have audio.
Cheers'
Mike
Jan 09, 2010 | EliteGroup ECS MB L7VMM+ W/ CPU-ATHLON...
How to install mercury audio driver in my computer
please install your audio driver Via ac97 driver express install
Nov 22, 2009 | Mercury P4VM800M7 Motherboard
No sound output
You'll want to verify that the onboard audio is enabled within the bios first, beyond that the audio codecs for that mobo should be the Realtek AC97 drivers, go to this link to obtain them. You have a choice of two - the AC97 standard codecs or the HD codecs (I would probably try the HD codecs first). I would also be curious as to whether the audio hardware is showing up in the device manager at all (especially if it has the yellow exclamation point next to it).
Based on what you posted about a bios update being the catalyst I would definitely check the onboard audio enabled within the bios option first...
Please post a little more info (especially about what the device manager says) or your results from the reinstall of the AC97 drivers...
May 04, 2009 | Computers & Internet
ASUS P4SGX-MX Motherboard Logo
2,437 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
