Question about Smeg S1100MFX5 Electric Single Oven
Indesit fan oven blowing cold air
My fan oven is blowing cold air do you know how to fix it??
  • Anonymous Aug 18, 2008
    I have the same problem - controls light up and fan works, but no heat. Any solutions?
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: smeg oven
Sounds like you need a new oven element fitting.
Posted on Dec 08, 2008
  • 18 Answers
SOURCE: Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
Posted on May 17, 2009
barkencoa
  • 3463 Answers
SOURCE: cannon oven not working
If the fan is working o/k, then it is sure to be the oven element that is faulty, a common fault with fan ovens, replace element, and it should be o/k.
Please rate my soluti9on.
Thanks.
Posted on Jul 19, 2009
apart4u
  • 213 Answers
SOURCE: electric main oven fan blows out only cold air
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
Ec600 dodlm model the fan oven is only blowing cold air
check for blown oven fuse. replace heating element in the oven
Jan 30, 2015 | Ovens
Fan oven blowing cold
The fan inside an oven is usually for convection cooking. It circulates air that is already heated. It is not a heater.
Apr 29, 2014 | Candy Ovens
Oven blowing out cold air
You need to replace the oven element This is located at thr rear of the oven compartment.
If there are no screws securing cover at rear of oven compartment, then you are going to have access it from the rear of the oven cabinet, on the outside.
Hope this helps.
Dec 20, 2009 | Candy Ovens
Fan oven blowing cold air
If it is the main oven blowing cold, then you need to replace the oven element.
This is located at the rear of the oven, behind a removeable cover.
This should solve the problem.
Dec 14, 2009 | Neff U1721 Double circotherm Electric Oven
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
May 17, 2009 | Whirlpool AKZ159IX Oven
Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Smeg S1100MFX5 Electric Single Oven Logo
270 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
