Question about Microwave Ovens
Hi there. I have a panasonic mocrowave model no. NE-1037 When i turn it on almost everytime it gives me an error warning Error code F33 How do i stop this and why does it happen? Regards
  • 100 Answers
F33 is usually a code indicating a faulty ground to the control board.
The usual culprit is the top screw that holds the control panel assy in place. Remove that screw, clean around the screw hole and lightly sand the area to insure a good ground. If you have one, install a star washer on the screw, replace, and tighten really well.
That will usually fix your problem!
Posted on Jul 23, 2008
F14 error code comes up after heating starts and shuts down.
this is special error. You must go to the panasonic ONLINE. give your model, and ask a question for get support ONLINE free, and fix it.
God bless you
Jun 15, 2013 | Panasonic Pro II NE2180 2100 Watts...
When turned off after cooling for 5hr. The outside unit buzzers as if a motor is running. it has gone on for 3hr. if I turn the unit back on it works OK just the outside unit seems to keep going.the out...
Do you mean after cooking for 5 hours? If so, yes. This is normal behavior. The microwave is running an internal fan to cool the components inside of the microwave. The fact that it has done so for 3 hours is a bit strange, but I doubt there is any issue with the inverter. Watch for errors. Error F33 or F34 mean an excessive heat build up in the microwave. Errors F81, F82, F83 and F84 mean that there is an issue with power delivery, such as inverter failure. While F86, F87, F88 and F89 represent shorted contacts within the microwave's boards and power supply.
Hope this helps,
~KenjiFox
Jan 07, 2011 | Panasonic F606Y6G00CP F606Y6G00CP Inverter
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
Panasonic microwave ne1446 fault 33
F33 or F34 codes may be triggered by either excessive heat within the oven or poor grounding of either the temp sensor or the controller (DPU) board. Check the following:
a) Clogged air filter (not applicable to OCS models)
b) Obstruction of the exhaust duct or insufficient ventilation
c) Defective thermal sensor (should read 30 – 70 kohm in room temperature)
d) Grounding of the thermal sensor (possible oxidation)
e) Poor connection (oxidation) at CN4 connector (PRO-1 models only)
f) Poor or no ground at the controller (DPU) board – ensure that all screws securing the board are in place
g) Missing screw(s) that secure the escutcheon to the frame (OCS models only)
h) If all steps above check OK, the error(s) may be caused by defective controller (DPU) board
Aug 11, 2008 | Panasonic Microwave Ovens
I have a Panasonic Microwave Model no. NE 1037 Almost everytime i turn it on it gives me an Error code F33 How do i stop this from happening and why does it happen?
F33 or F34
These codes may be triggered by either excessive heat within the oven or poor grounding of either the temp sensor or the controller (DPU) board. Check the following:
c) Defective thermal sensor (should read 30 – 70k ohm in room temperature)
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Microwave Ovens
M# 1757 S#E14250048 Error Code F 21
That is the correct model #
Also I don't find an F21 error code in my manual also ????, Thanks for any help you can give me.
Alan
Jul 08, 2008 | Panasonic Microwave Ovens
Microwave runs for a few seconds then F 12 displays on screen and it stops
The following is a solution for the Panasonic brand microwave. I do not know your brand so this is the best I can do.
PANASONIC
Model: NE-1057, NE-1057C, NE-1257, NE-1077, NE-1277, NE-1457, NE-1457C, NE-1757, NE-1477, NE-1777 Symptom: Code "F11" or "F12" appears on the display intermittently Problem: Moisture is accumulating on control panel from steam rising out of the door. Solution: Install foam sealer (cushion rubber) along lower edge of control panel escutcheon. Part # A8251-3180
Apr 03, 2008 | Microwave Ovens
Microwave Ovens Logo
119 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
