Question about Microwave Ovens
I have a Panasonic Microwave Model no. NE 1037 Almost everytime i turn it on it gives me an Error code F33 How do i stop this from happening and why does it happen?
  • Microwave Ovens Master
  • 9,098 Answers
F33 or F34
These codes may be triggered by either excessive heat within the oven or poor grounding of either the temp sensor or the controller (DPU) board. Check the following:
a) Clogged air filter (not applicable to OCS models)
b) Obstruction of the exhaust duct or insufficient ventilation
c) Defective thermal sensor (should read 30 – 70k ohm in room temperature)
d) Grounding of the thermal sensor (possible oxidation)
e) Poor connection (oxidation) at CN4 connector (PRO-1 models only)
f) Poor or no ground at the controller (DPU) board – ensure that all screws securing the board are in place
g) Missing screw(s) that secure the escutcheon to the frame (OCS models only)
h) If all steps above check OK, the error(s) may be caused by defective controller (DPU) board
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
F14 error code comes up after heating starts and shuts down.
this is special error. You must go to the panasonic ONLINE. give your model, and ask a question for get support ONLINE free, and fix it.
God bless you
Jun 15, 2013 | Panasonic Pro II NE2180 2100 Watts...
Panasonic microwave S333 just stopped suddenly. I see on the internet that this has happened to others after about 2 yrs use. Any solution suggestion is appreciated.
Did it show an error code in the display?
If it showed H-98 or similar the magnetron has failed.
It is not a customer repairable item. Take it or have an Authorised Panasonic service centre look at it.
Jan 19, 2011 | Panasonic NN-T694SF Microwave Oven
Panasonic NE-1780 - F14
Could be a problem with the door latch, or the magnetron or magnetron circuit.
Aug 02, 2009 | Panasonic Microwave Ovens
Microwave shuts off before time elapes
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
If you prefer, you can find an authorized Panasonic servicer here.
Dec 07, 2008 | Panasonic NN-T990SA Microwave Oven
Replacement part for microwave
That would have been # ANE06012L0APbut it is listed as no longer available from normal distributors.
It looks like you can still order it here.
Dec 04, 2008 | Microwave Ovens
Looking for parts for my Panasonic Microwave Model No 9970C9870C
The proper model number format would be NE-9970C or NE-9870C.
You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
I would suggest searching by just the root model number without the C suffix.
If you're still having trouble, please replay back with your specific model (from the tag on the unit) and let us know which parts you need.
Oct 13, 2008 | Panasonic Microwave Ovens
Hi there. I have a panasonic mocrowave model no. NE-1037 When i turn it on almost everytime it gives me an error warning Error code F33 How do i stop this and why does it happen? Regards
F33 is usually a code indicating a faulty ground to the control board.
The usual culprit is the top screw that holds the control panel assy in place. Remove that screw, clean around the screw hole and lightly sand the area to insure a good ground. If you have one, install a star washer on the screw, replace, and tighten really well.
That will usually fix your problem!
Jul 23, 2008 | Microwave Ovens
Microwave runs for a few seconds then F 12 displays on screen and it stops
The following is a solution for the Panasonic brand microwave. I do not know your brand so this is the best I can do.
PANASONIC
Model: NE-1057, NE-1057C, NE-1257, NE-1077, NE-1277, NE-1457, NE-1457C, NE-1757, NE-1477, NE-1777 Symptom: Code "F11" or "F12" appears on the display intermittently Problem: Moisture is accumulating on control panel from steam rising out of the door. Solution: Install foam sealer (cushion rubber) along lower edge of control panel escutcheon. Part # A8251-3180
Apr 03, 2008 | Microwave Ovens
Microwave Ovens Logo
175 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
