Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY 4 G USB DISK IS WRITE PROTECTED
HOW DO I REMOVE THE WRITE PROTECTION AND FORMAT
  • 1 more comment
  • sharondippen Jul 23, 2008
    tried that did not work. said i should download a flile to do a low level format but wouldnt work. so i am still stuck
  • nwade Jul 29, 2008
    Exact same problem and experience with PNY.
  • Sam Ash Oct 02, 2008
    I tried searching the web for a solution and none of them work, maybe we should call the company!
  • 28 Answers
Not sure what exactly is happening when you try to use the disk. Is it a used disk? Did you just purchase it? Do you get an error when trying to use it?
From the limited information, I would suggest going to the website and seeing if there is a solution from PNY: http://www2.pny.com/support/support_landing_cat.aspx?SectionID=1143 (their support page).
If it still doesn't work, post more details & I'll see if I can help.
Have a good day!
Posted on Jul 23, 2008
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
Write protected PNY 4GB USB
Go to Start
Click Right mouse button on Computer
Click on Manage
Click on Disk Management
In the Right Panel of the drive you wish to fix
Click Delete Volume
When Volume is deleted
Click Create Volume
Follow the steps
For small drives use Fat32 not NTFS
NTFS is not portable between XP and Win 7
You may also have a virus.
Mar 27, 2014 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to format a write protected flash disk
You can download a tiny software which can remove write protected and then you can format it .
http://www.box.net/shared/9hgp81ndgs
or if you want to do it manually then here are the steps.
(Remeber to back up Registry before doing the below steps)
1.Go to Run->regedit
2.MyComputer->HKEY_LOCAL_MACHINE->SYSTEM->CurrentControlSet->Control -> StorageDevicePolicies
3.Delete the StorageDevicePolicies in Your Registry.
Aug 07, 2012 | PNY 16GB HP USB Flash Drive v255w - USB...
Cannot format flash drive.... receive message `disk is write protected`
Usually there is a small switch or colored slide which flips between write protected and writable. If there is no switch it may be the software that is on the drive is preventing the format, if this is the case you may need to use a boot disk like Hiren's boot Cd to format it while not booted into Windows.
Mar 15, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Genx usb flash 128 Mg is write protect how i can remove write protect
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 27, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
I cannot copy files from computer to my phone memory card
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 15, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How do i remove the write protection on pny 8GB usb flash drive
Here is the answer from PNY.
http://www2.pny.com/support/support_single_faq_viewer.aspx?ArticleID=1415&RootSectionID=1057
Be warned, this is a low level format tool from them. What ever is on your flash drive will be erased.
I went exploring on these drives and found that when they start acting like they are write protected, it means that the drive corrupted. The low level format tool, will completely reformat that drive, and hopefully correct the problem.
They say it happens (usually) if you removed the drive from a computer, without using the safe eject USB function.
If this is a new flash drive, take it back to where you got it, and ask for a replacement.
Sep 08, 2008 | Computers & Internet
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
1,016 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
