Question about Nintendo Wii Console
No instuctions for nintendo wii
All plugged in ,power on no picture on tv.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey audstaples,
If you're sure that your Nintendo Wii is correctly connected, you may only need to change the input station on your TV. While some TV's will only require that it be on channel 3 or 4, many others are only able to recognize game consoles when set an external input station. Usually these stations can be found be pressing the "Input" button on the TV's remote control or by accessing the TV's main video setup menu, depending on the model that you own.
Should changing the input not resolve the problem, you may wish to double-check your connections using the setup troubleshooting guide provided by Nintendo through the following link:
http://www.nintendo.com/consumer/systems/wii/en_na/setupAV.jsp
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 23, 2008
I accidentally set my wii to HDTV settings and I need to reset it back to normal tv but my screen is so messed up I cant see options or anything
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
May 01, 2011 | Nintendo Wii Console
Tip
Reset your Wii Video Settings to the Default
One annoying thing about the Nintendo Wii is that there is no way to reset the video settings once you have changed them in the Nintendo Wii System Menu.
It will not detect which cables you are trying to use and just tries to use the last settings that you set it to.
So, if you have changed your Nintendo Wii from using the regular cables that came with the system to using component cables, then switch back to a TV using regular RCA cables (these are the yellow, red and white cables) then you need to reset the settings on your Nintendo Wii to the default video settings.
I hope this tip helps!
on Apr 09, 2010 | Video Game Consoles & Games
My Wii doesn't come on
Hi there, you could try the following:
  1. Try unplugging Wii from the power for a full 2 minutes, plug back in and power up and test (This resets the Power Adapter).
  2. If this does not resolve it then it may need to be repaired so contact Nintendo here.
Please see here for for information on Power issues with the Wii.
Cheers
Apr 03, 2010 | Nintendo Wii Console
The picture on my nintendo wii will not come up on the t.v.
your wires are not inserted right try and look on the back of your tv and plug the wires were there suppose to be..
Mar 27, 2010 | Nintendo Wii Console
Help me to put up my nintendo wii
1- Plug the video cable to both wii and T.V.
2- Plug the wii sensor in wii and place it at top of T.V.
3- Plug the power cord in both wii and electrical supply.
4- Press the power button and sync your wii remote.
Mar 13, 2010 | Nintendo Wii Console
No picture on nintendo wii
make sure the red, white, and yellow cords are attached securely to the tv.
Jan 04, 2009 | Nintendo Wii Console
Power but no picture or sound
Did you plug in the cables in the TV for the Wii? Check if you did that or if you do, try changing the different TV setting.
Mar 09, 2008 | Nintendo Wii Console
Problem with wii
try unplugging the console the power button never turn off ever anyways check the connection and try a differnet tv and if all else fails call nintendo they should have a fix
Dec 31, 2007 | Nintendo Wii Console
Connecting Nintendo Wii to JVC television
every time im using my wii in my jvc tv i keep clicking channel the when i click the tv button on the rca remote then a code. i keep forgething the code
Dec 28, 2007 | Televison & Video
Nintendo Wii Console Logo
49 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
