Sat nav not responding on touch screen peugeot 207 sportium
If the sat nav is not responding to touch on the touch screen of your Peugeot 207 Sportium, there are a few things you can try:
Check if the screen is clean: Sometimes, the touch screen may not work if there is dirt or debris on it. Use a clean and soft cloth to wipe the screen.
Restart the system: Try restarting the sat nav system by turning off the car and turning it back on again.
Check the settings: Check if the touch screen settings are correct. In some cases, the touch screen may be turned off in the settings, so make sure it is turned on.
Update the software: If the sat nav software is outdated, it may not work properly. Check for any available updates and install them.
If none of these steps work, it may be a hardware issue and you may need to take the car to a mechanic or Peugeot dealer to diagnose and fix the problem.
I have a 2003 crv with the same problem. t cannot be fixed easily or cheaply, Laser realignment?
Honda rae unhelpful
