Problem:
The seal design on the washer traps water causing mildew to grow.
Solution:
If
the door gasket has a small hole at the six o'clock position--it is
clogged with soap scum. Use compressed air to blow this hole clear.
This allows water to drain back into the tub
If there's no hole--this is an older model LG which did not have this upgrade
Wiping
the door gasket with a rag after the LAST cycle of the day helps
prevent debris from accumulating. Some consumers add (1) teaspoon of
bleach to a spray bottle with water--and spray the older type gaskets
after the final laundry load finished--to keep the gasket clean.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
