Question about HP Pavilion dv9000z Notebook
HP Pavillion 9000 Display Problem
Hi I have a problem with my laptop the thing starts but the screen stays blank until the log on screen then i horizontal lines across the screen i log in to windows vista then the desktop starts but i get triangulation of graphics on screen that keep moving around, i have managed to start the pc in safe mode but i can only see the screen on an external monitor when i start the pc normally with the external monitor conected i can still only see the triangulated screen, i would just change the graphics card to see if this solved it but i think its part of the Curcuit board / Any ideas gratefully accepted Paul
Hi i seem to have solved the problem using a seperate display and running in safe mode, using safe mode i was able to run "spyware doctor" and "reg edit" both found problems, spyware doctor found a trojan in a hidden folder with a deep scan that took over an hour and a half, it was critical and could not be identified,
Regedit had backup files and found 200 problems that it fixed i changed the PC to start in default configuration and then restarted without the external monitor and all seems ok
Posted on Jul 23, 2008
No display on laptop screen and external monitor to perform any action on hp PAVILION DV9700
use some special function key combination you activate it for output vedio device such key combication start fn key + function key to display output
May 19, 2012 | HP Computers & Internet
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
Does HP Pavillion DV 9000 laptop has a HDMI port for linking up with a HDTC? - Sanjay
Sorry the HP Pavillion DV 9000 doesn't have an HDMI port.
Regards.
Jan 12, 2011 | HP Pavilion dv9000z Notebook
Hi, I have a HP PAvillion 9000 series laptop. When I turn it on its just a black screen and no cursor is there. I can then hear windows loading but screen remains blank. The BIOS doesnt even appear on...
Hi !
I believe that your operating system is corrupted and need reformat your computer. It will not boot to Bios because it is corrupted.
Here is the link on how to reinstall your operating system http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean.
Good Luck and thank you for using FixYa !
Jan 07, 2011 | Computers & Internet
Blank Screen on start. No display
You need to replace the motherboard. When nothing comes on the display this means the bios on the motherboard is bad and the board and cpu need replaced.
Mar 17, 2010 | HP Pavilion dv2000t Notebook
HP Pavillion DV4000 notebook display shading
It sounds very much like an inverter issue. The inverter sits under the lcd screen in the screen plastics. It is replaceable, but obviously there is a danger the screen may get damaged.
Nov 21, 2009 | HP Computers & Internet
My HP Pavillion laptop turns on but the screen doesn't show.
You could be expierencing a problem with your monitor screen. try this.... connect another monitor screen to the VGA port of your laptop. Now try booting up. Look for and push Fn + the key that turns on a secondary display. if the monitor screen comes on. you need
another laptop monitor. At least you can use your laptop with the second monitor for now.
Jun 16, 2009 | HP Pavilion dv9000z Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavillion dv5000 laptop will not load windows.
I had this problem, because I have had my HP Pavillion Dv 9000 laptop replaced 3 times. There is a recall on those laptops. The mother board is no good. HP fixes the problem at no cost to you even if it is out of warranty. There is also a freeware and software BIOS update that was just released. And if your screen ever cracks there is a recall on that as well with the left display hindge. My solution: Call HP at 800-474-6836 they are available 24/7 365. Make sure you have your notebook Model number and serial number ready.
Mar 18, 2009 | HP Pavilion dv6000z Notebook
Freezing then blank screen
Have you tried pressing F8 on boot-up and log into safe mode under administrator, no password, and right click on any empty space on the desktop, left click on properties, left click on settings, select a lower resolution,( e.g. 1024X768 ) select apply, select ok, reboot, log in as normal
Mar 26, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv9000z Notebook Logo
127 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
