Question about PfaFF Creative 7570
7570 Pfaff - stitch length
I recently completed some embroidery work and then switched back to regular sewing. The stitch length is not changing -- it is either real tiny or real big. It won't go in reverse.
  • 1 more comment
  • ladysif Jul 23, 2008
    I did - several times to make sure something wasn't impeding it.
    Additional info -- it runs in reverse only now.
  • alacrity Dec 10, 2008
    I have the 2048 - but the same thing is happening. Last night, on the straight stitch, no matter what length I chose, the stitches were very tiny. I decided to try it again just now, and guess what?! Now it only sews in reverse. Very strange.
  • 3 Answers
Make sure you raised the feed dogs.
Posted on Jul 23, 2008
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
What format does the Pfaff 7570 use for embroidery?
The format that is used by the 7570 and the 7560 is *.pcs or *.dst. Either one will work provided that the designs are within the confines of the hoop. The largest size design that would be embroidered by this machine would be 115 x 120 MM.
Jan 03, 2013 | PfaFF Creative 7570
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
I have inherted a Pfaff 7550 and do not know how to use the maxi stitch function or to enlarge embroidery stitches
Contact a local Pfaff dealer for a manual or ask if they have lessons.
This is not as easy as the spoken word.
Mar 15, 2010 | PfaFF Creative 7570
Pfaffa 7570 Creative Fantasy Embroidery Unit does not move
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
Apr 08, 2008 | PfaFF Creative 7570
Pfaff 7570 Sewing Slow
Unfortunately, this is most likely a computer board issue and there's just no way to predict if/when a board will go bad.
Your only option at this point is to take it to an authorized Pfaff dealer. If the person who serviced it was an authorized Pfaff tech, take it back to them. If not, do take it to a Pfaff dealer - non-Pfaff authorized techs are not trained on the machines.
Sorry I can't give you a simpler answer, but until this is corrected, your machine won't work properly.
Best,
Kim
Mar 18, 2008 | PfaFF Creative 7570
7570 sewing machine
contact a pfaff dealer in your area., and they will order what you want
Dec 11, 2007 | PfaFF Creative 7570
Sewing from m-memory
Hi Ann,
m-memories are not stitched with the hoop or embroidery unit. They are stitched with the #2 sewing foot and with the feed dogs up just like any of the 9mm decorative stitches on the machine.
Linnette
Nov 07, 2007 | PfaFF Creative 7570
Sewing Machines Logo
169 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
