Question about HP LaserJet 2420 Printer
Memory error when i try to print it display 10.10.00 supply memory error so cannot print
  • sobah Jul 23, 2008
    no use
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Posted on Sep 19, 2008
  • 300 Answers
Follow this -
1. Turn the printer off, and then
turn the printer on to clear the
message.
2. If the message persists, open
the top cover, remove the
print cartridge, and then
reinstall it.
3. If the message persists,
install a new HP print cartridge.
4. If the message persists,
check the connection
between the ECU and the
memory chip on the print
cartridge.
5. If the message persists,
replace the memory chip
cable and contact assembly.
6. If the message persists,
replace the ECU
Posted on Jul 23, 2008
3 Suggested Answers
Dadofmykids
  • 25 Answers
SOURCE: hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
Posted on Apr 07, 2009
nandini789
  • 430 Answers
SOURCE: When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Posted on Aug 30, 2009
10/1000 supply memory error
Try to reinstall the driver, or to print page by page.
Sep 15, 2012 | HP LaserJet P2055d Printer
Printer giving supply memory error
Try this:
10.XX.YY SUPPLY MEMORY ERROR
For help press
The device cannot read or write to the print cartridge
memory tag, or the memory tag is
missing.
1. Open the cartridge door.
2. Remove the print cartridge, and then
reinstall it.
3. Close the cartridge door.
4. Turn the device off and then on.
5. Verify that a genuine HP print cartridge
is installed in the device.
6. Install another print cartridge.
7. Verify that the memory tag PCA is
8. Verify that the memory tag connector is
firmly seated in connector J510 on the
ECU. You might have to remove the
main cooling fan to see this connection.
9. If the error persists, contact HP Support.
Jun 28, 2011 | HP LaserJet P3005 Printer
10.1000 memory error
Thank you for contacting FixYa with your printer inquiry.
This error is normally associated with a supplies error. I have extracted information on this error from the HP 6L manual.
Error Codes
Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
    XX Description 00 memory error on the cartridge or 01 memory device not found
    10.00.00 Black print cartridge
    10.00.01 Cyan print cartridge
    10.00.02 Magenta print cartridge
    10.00.03 Yellow print cartridge
  1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
  2. Replace the memory chip cable/connector or the DC controller.
    How did we do?
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 08, 2011 | HP : HP6L Laserjet Printer
I have HP Laserjet 5200N printer, i am not able to print due to error massege "10.00.00 Supply Memory Error". thanks Mohammad Hittini Director of IT Moevenpick Resort & Spa Dead...
Not sure if you have tried the HP knowledgebase, but there are a few steps they recommended trying.
Here is the direct link, but I copied the relevant information into my reply.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl51389&locale=en_US#A3
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
  7. If the error does not clear, contact HP support.
10.10.00 SUPPLIES MEMORY ERROR alternates with For help press ? Possible printer control panel error message 10.10.00 SUPPLIES MEMORY ERROR Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 10 = memory is missing
yy
Action
  1. Turn the printer power off, and then turn the printer power on to clear the message.
  2. If the message persists, click here to access to the HP support Web site at http://www.hp.com/support/lj2300 .
Jan 01, 2011 | Computers & Internet
10.0000 supply memory error (Problem
This is a problem with the toner cartridge, replace the toner and try an nvram:
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Al
May 21, 2010 | HP LaserJet M1522n MultiFunction Printer
HP Printer not printing, activated error code -20
Error 20 Memory Overflow / Insufficient Memory
  • A large print job has exceeded the memory capacity of the printer. Verify that the SIMMS or memory cards are seated. Add more memory or simplify the print job. Remember the original HP Laserjet has only 128K of memory available, the LJ+ has only 512K and neither one is really upgradable.
  • On the 5P turn the image adapt and page protect to ON or AUTO. These can be set within the Remote Control Panel. Press GO to resume printing.
  • On the 5L, set the Enhanced I/O to AUTO (PCL mode) and resend the print job
Nov 24, 2009 | HP Office Equipment & Supplies
I am getting 10.00.01 memory supply error on the cyan cartridge of my HP color laserjet 3500. The cartridge is nearly full and was working fine. I have tried cleaning the memory controller PCB contacts but...
I had a like problem and found that the chip on the cartridge was mounted without enough spacer such that contact was not being made with the memory controller PCB connector.  I cut some two-sided tape and put it behind the chip such that it stuck out further so that better contact could be made and the problem was solved.
Apr 28, 2009 | HP Color LaserJet 3500 Printer
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
Turn on the printer.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
Jan 15, 2009 | HP LaserJet 4600dn Color Printer
HP LaserJet 2420 Printer Logo
2,189 people viewed this question
Ben Johnson
