This problem is most often the CCU circuit board (inside, top, back, plastic case) there are bad solder joints on the circuit board where the relays (5 of them) and the spade connectors are supposed to be firmly soldered to the board. Often times the vibration of the machine will make or break one of these connections causing the machine to stop at various times. The cure is to remove the CCU case then the circuit board and touch-up those solder joints I mentioned. If your not up on soldering techniques you can remove the CCU case and circuit board and take them, along with this response, to a good appliance repair shop and they should be able to help you out. Good luck.
