Question about Whirlpool AWM6120 Front Load Washer
Whirlpool Front loading washing Machine Model AWM8121 - Problem: Machine does not engage in any of the cycles. Pump seems to be working as it engages as per normal at the beginning of any cycle. But once the initial pump process completes nothing else happens. Also once this process happens the door open light begins to flash continually. I've cleaned the filter making sure there are no trapped foreign bodies present (all pumps hoses have been removed, cleared & repositioned). Water inlet hoses have all be checked. Power to the machine is fine. Please suggest a remedy.
    Problem Solver:
  • 4 Answers
Try checking the brushes in the motor.
Posted on Dec 13, 2008
Try playing around with the door switch. Access it by taking spring off the front rubber seal.
Posted on Apr 25, 2014
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
Water won't drain, spin cycle won't engage
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore washer spin cycle will not engage / motor is spinning but not engaging prop to spin out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Kenmore Washing Machines
Whirlpool AWM8121 stops working mid cycle. Bottom two lights flashing on spin speeds.
Fault code 3 = Drain failure or not detecting empty drum.
Check pressure switch, blocked drain, drain pump.
See link below for service manual.
http://www.user-manuals.com/advanced_search_result.php?keywords=857081253000&forward=plist
Oct 24, 2008 | Whirlpool AWM6120 Front Load Washer
I have a Whirlpool front loading washing machine (model AWM8121). We keep getting sporadic bleach marks on our towels and clothing when we take them out of the washing machine. Any idea what might be...
try removing dispenser drawer completely and cleaning thoroughly there may a buildup in drawer preventing the bleach from completely dispensing properly at the proper time ..press tab down on left rear corner to completely remove entire assembly
Aug 19, 2008 | Whirlpool Washing Machines
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM6120 Front Load Washer Logo
474 people viewed this question
Dan Webster
Dan Webster
Sal De
