Question about NEC MobilePro 900 Handheld
Sync probl i have winsdows vista and it does not allow to downlaod sync 3.5 for my mobile pro 900. Is there any solutions to sync this to my computer
    Genius:
  • 1,019 Answers
Windows Vista is a nuisance, in my own experience.
it has too many issues with drivers et,c.
i,d suggest seeking the setup cd, that would have been packaged with your Hand-held, Or PDA.
This would have had various Applications on it. And Also Active-Sync 3.5. However Vista. Will probably run or use Active-Sync 4.0. which is available from M$ Site. if you download from a computer running Windows 2000 Or XP. then put onto a memory card, or burn to a CD. that you can then install onto your PC.
Long-term, i,d suggest Considering XP. as a more stable and reliable Operating System.
Hope this Helps.
Mike @ Compurepair.
Posted on Jul 23, 2008
I cannot access windows vista to sync with my hp 6310 ipaq
Greetings - I'm going to guess that perhaps you installed Activesync 4.5, For Vista or Windows 7 you have to install Windows Mobile Device Center which is available HERE.
If you are using mobile device center that isn't the problem and Microsoft has a dedicated section of their website dedicated to solutions syncing Windows Mobile device with Vista, way too much for me to go over here. There's a great deal of trouble shooting information about sync problems HERE.
Thanks for using Fix Ya
Mikeywaf
Mar 16, 2011 | HP iPAQ H6310
Mobile Pro 900
Maybe you can try disassembling it and see if it's damaged.
Heres a repair guide with images:
http://www.hpcnec.com/cgi-bin/simpleforum.cgi?fid=12&topic_id=1143848182
Dec 10, 2007 | Computers & Internet
I am having problems syncing my samsung G600 with vista
try to sync it outside of pc studio, as a mass storage device would work.
Nov 03, 2009 | Nokia 1100
I'm running Vista and I'm having trouble with my HX2415.I have Windows Mobile Device Center Installed. When I plug the unit into a USB port it doesn't find the hardware. It worked fine on XP with Active...
Hi
Thanks for using FixYa. HP ipaq HX2415 is compatible with Windows Vista Mobile Device center Version 6.1. Please check if you are using version 6.1, you can download the Windows Vista Mobile Device center Version 6.1 from this link--
Windows Vista Mobile Device center Version 6.1 Link
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 07, 2009 | HP iPAQ HX2415 Pocket PC
I cannot get my nec mobile pro 900 to sync with my laptop i downloaded activesync from: http://www.microsoft.com/windowsmobile/en-us/downloads/eulas/eula_activesync45_1033.mspx?ProductID=76 i downloaded...
Which one did you do first: Did you install ActiveSync 4.5 first, or did you try installing the driver first?
The best way to do this is as follows:
  1. Download and install ActiveSync (4.5 is what i use both at home and work and it works great with the NEC 900 and 900C's.
  2. Restart your Windows XP Machine (I assume you don't have Vista)
  3. Next, follow the instructions for the installing the NEC 900 usb drivers (these drivers should be installed AFTER installing ActiveSync... (it seems to work that way without problems for me).
  4. Next, restart your xp machine again.
  5. Now, connect your NEC MobilePro 900 to your Windows XP machine, and it should perform smoothly.
If this does not work for you, you can contact the folks at usedhandhelds.com, they sell and repair, as well as provide support for these machines.
Hope this helps
Apr 17, 2009 | NEC MobilePro 900 Handheld
How do I sync?
If its not installed you need to downlaod Windows Mobile Device Center here : http://www.microsoft.com/downloads/details.aspx?FamilyID=46f72df1-e46a-4a5f-a791-09f07aaa1914&DisplayLang=en
Then just follow the instructions!
Jun 23, 2008 | HP iPAQ H5550 Pocket PC
Sync PDA problem
Uninstall the Mobile Device Center. Be sure to download and install the LATEST from Microsoft. Make sure your device is NOT connected until after installtion. DISABLE all firewalls for a 15 minute interval. Then just plug in and you should bet set. When you reboot you should be good you may get a pop-up from your firewall, just allow it.
May 20, 2008 | Computers & Internet
Can not connect using LG Mobile Sync
Hi all,
I went through the same trouble. After a small investigation I've found that the USB driver wasn't install. I just ran the setup and it worked imediatly C:\Program Files\LGE GSM PC Sync\USB Setup\LGUSBModemDriver_ML_WHQL_Ver_4.6.exe
Hope it could help!
Feb 03, 2008 | LG Shine KE970 Cellular Phone
Sync toshiba pda to pc w/vista
I also have had this problem.
If you allow the Windows Mobile Device Center to install through the automatic updates, it works for the most part. I've gotten it to actually sync both from the pc to the pda and vice versa. However, it is a little finicky; it takes about 4 attempts before the sync is happy.
Jan 05, 2008 | Toshiba e335 Pocket PC
Syncing of palm times out
this is producers mistake :(
Sep 23, 2007 | Palm Treo 750 Smartphone
NEC MobilePro 900 Handheld Logo
113 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
