Keston c40 honeywel 9400c programmer for central heating and hot water control and st 6100 for separate control of under floor heating circuit with polyplumb manifold and pump. cyl stat l641a 2x room stats t6360 .. need your help with a wiring diagram please?
  • Anonymous Jul 24, 2008
    hanoywell st 9400c programmer ( click when programmer off)
    and timer get warm,,and why timer junps when off ,,,,,,
Do a s plan plus and buy a poly plumb roomstat combined programer with built in relays as you require the relays to stop back feed! simple!
Posted on Jul 23, 2008
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
I have a Honeywell ST499A/ST699B "Central Heating Microelectronic Time Controller" managing the operation of my house boiler. The time controls are set properly. PROBLEM: If I want either hot water or...
I have an old Honeywell ST499A/ST699B thermostat. It still works OK but when we have a power cut I have to re-programme everything. Presumably this is because the battery needs replacing. I cannot find a way of opening the control box to get into the unit to replace the battery and in any case I’m not sure if the battery is renewable?
Oct 12, 2009 | Honeywell Programmable Thermostat Heater
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
258 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
