Have got a laptop going to a amplifier and the 4 speakers are running.i have just bought a digtop 4 way stero speaker swith box so i can turn of what speakers i want.what do i have to do 4 this
  • 2,071 Answers
I agree what thebloms comment it is in auxiliary connection,it is better you a Sling box for multiconnection...
hope this may help;
Regards,
VOTIT
DON'T forget to rate...
Posted on Jul 25, 2008
  • 3 Answers
Boy a bit hard to figure out what your saying
but your laptop goes into a aux input on the receiver then the speaker box hooks to the the left and right output on the receiver. you just use the main outputs or A outputs then the speakers all four hook to the speaker switch box
I think this is what you are wanting but hard to tell with the info you gave.
Mark
Posted on Jul 24, 2008
IVE BOUGHT MY SELF A TECNICS STERO INTERGRATED AMPLIFIER SU-610.AND IAM NOT SURE WHICH SPEAKER LPUGS OR JACKS TO USE
You kiddin'? The speaker jacks are very clearly labeled on the back. It's the biggest label there. It's one third of the back panel!
R means the RIGHT speaker as you face them. L means the LEFT speaker.
You can attach two sets of speakers if you choose. One set is called A, the other is called B. Pick one or the other.
The speaker wire that goes into the + / PLUS / RED connector goes into the + / PLUS / RED connector of your speaker. The minus wire goes into the speaker's minus connector.
Enjoy the music.
Nov 06, 2012 | Audio Players & Recorders
REAR door speakers dont work in 98 gmc c1500 suburan
Hi, generally when you a buy a car, the steroe and speakers are all stock fitted, if bought second hand, they may have been upgraded.
Down to your speakers, check connectors behind the steroe unit, should be 2 plugs, one for power with red, black, yellow and blue wires, and the other plug is your speakers. Check there is 8 wires into the plug.
If all is correct then check the rear of your speakers, check the connection and that the wire isnt loose.
If all is fine there must be a wire break somewhere, your stereo presets are only set to the front speakers (fade setting).
Hope this helps
Mar 08, 2012 | Car Audio & Video
Good afternoon, I recently bought a SA VE325 speaker set it contained a subwoofer, 4 little boxes and a mid-large box which you haeb have tpo piuyt above uyour tv. Now the problem is we have no cCENTER to...
Hello there looking at the manual i would assume that the mid-large box is actually your centre speaker.
Did you mean that there are no connections left on the back of your amplifier? For a centre speaker this system uses all passive speakers apart from the subwoofer which has a built in amplifier for just the subwoofer, your hifi or home cinema amplifier would need to have at least 5 separate channels to operate the centre speaker as well as the front and rear speakers.
Ideally you would need a 5.1 channel or 5 channel amplifier with subwoofer pre output, any would do but to make things simple one with a digital optical or coaxial input would be best as this can easily carry multi-channel audio with just one connector.
The other alternative if your amplifier does not have a centre speaker output are:
· to get another basic mono stereo amplifier to power the centre speaker on its own however if your main amplifier does not have a pre out connector for a centre speaker you will have to change the volume independently on both amplifiers
· don
Aug 27, 2011 | Sony SA-VE325 System
Convert a 4 om amp to play w/8 om speaker
Connect the two speakers in parallel. That will present a 4 Ohm load to the amp.
Dan
Sep 14, 2009 | Adcom GFA-5400 2-Channel Amplifier
Pioneer car audio amp GM 6300F (new)
Does your amplifier have a Channel swith which says 2/3/4 channel mode. If so and you are running the amplifier in Bridged mode, try changing the setting to 2 channel or Bridged mode.
Aug 20, 2009 | Pioneer GM-6300F Car Audio Amplifier
TAKE OUT STERO
First you need to go to Schoche.com and Purchase a Small Blue Box that will let you convert the Audio wires into RCA Jacks. Got one for my 2007 Scion Xa Worked Great! You will still need to run your wires for the amp and Run RCA Cables to the Stereo. This box will cut into the Rear Speaker wires and still allow the Speakers to work while allowing you to Connect the RCA Cables for the Amp to the Box.
Jan 18, 2009 | 2005 Scion xB
When i turn up the stero the power turns off and the red standby light flashes till i turn it back on
Firstly i would disconnect all speakers and turn amp up if still does it then there is an overload in amplifier anbd needs to be repaired..
If not then connect speaker 1 at a time and try amp volume again,you could also get a multimeter and check across speaker terminals on boxes for different resistance readings..
Jan 08, 2009 | Onkyo TX-SR601 Receiver
80 watt impedance matching volume control
check your spekaer cabling first for any loose connection. if everything as usual then something is wrong with either your speaker system or the power output stage of your amp. you may call it a "circuit breaker" but it actually overload protection of the power amp so as not to damage speakers or amplifiers. have your speakers checked for burn coils. you can also try to remove or turn off speaker switch, turn on the power, level up the volume and see it the system still stays on and does not trip (as you called circuit breaker) if the unit remains on, then it must be your speakers. though it could also be a leakage in the power transistors of your output stage, it something a technical person have to do to check anyway.
redrivera
Mar 25, 2008 | Audio Players & Recorders
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
 Grubhead
Grubhead
