WIRELESS ISSUES my toshipa P105 wireless connection does not get wireless signal.it was ok until few days ago and i have not changed anythiing on the settings.the wireless icon is enabled but it says that is not connected. thanks
  • 4 Answers
There are few options to test
Option 1) Check if the SSID and WEP key in the modem page
tally with your logon SSID or WEP key, because
limited connectivity issue happens when SSID and
WEP does not match
Option 2) Restart your modem
Option 3) Check wirings on telephone line , replace tephone line
with another telephone line and make sure the socket
plugged in from the telephone line is a BB tel number
and service has been paid promptly every month
Option 4) Change the wireless channel in the modem page to
detect the wireless device from 9-11 at 192.168.1.254
address in Internet explorer
Option 5) Bring laptop closer to the modem and ensure wireless
led on the modem is lighted and the wireless led from
the Laptop is enabled
Posted on Jul 23, 2008
  • Thoo Wai Kiat
    Thoo Wai Kiat Jul 23, 2008
    Andy Thoo from Singtel
My wireless router isn't working
I think you should reset the router and reconfigure it.
If the wired computer is also not working then I think you need to reconfigure it for sure.
See How to reset Linksys router.
Watch.
How to setup Linksys router without CD.
Feb 03, 2012 | Linksys Computers & Internet
My wireless connection was working fine up until a few days ago. Now, I can connect directly to my ethernet, but not through the wireless. It shows perfect signal strength, but no connection to the...
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
Aug 15, 2010 | Linksys Wireless-G WRT54G Router
Lap top WI-FI does not work with this WBR-1310...no signal showing connections...however, did work a few days ago. Using HP laptop Pavilion.
Make sure you didn't accidentally hit or tap the wireless button as that shuts off all internet connecting abilities.
Apr 10, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Bought a NetGear WPN111 RangeMax Wireless USB 2.0 Adapter a few months ago. It was working fine up until a few days ago. It started dropping my internet connection, and now it won't even detect any...
Hi
firstly you can try upgrading the drivers on the adapter. following is the link for the latest drivers http://kb.netgear.com/app/answers/detail/a_id/12520
If the problem still persists
try changing the wireless settings on the wireless router.
Nov 12, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Dell latitude cannot connect to wireless but can through ethernet
ever thought that the wireless card might be disabled or you set it to off?
Apr 18, 2009 | Dell Latitude C840 Notebook
D-Link Airplus di-524 wireless problem
Hello.
The status light is blinking in all dlink models, so that is normal.
The wireless radio issues have 3 possible solutions.
1. This model has a antenna that screws in the bnc socket behind it see if it's well screwed, or substitute it by another if 2 and 3 don't fix it.
2. On the advaced settings of the wireless configuration you have the ratio of radio broadcast from 25% to 100% check to see if it's on 100%, change channel to 11 if neer and 6 if far, make sure you have SSID broadcast enabled.
3. This models allow you to restart the AP unit and the router unit idependently, so it's always good pratice to restart your AP in the tools and system comands menu.
Hope that helps.
Feb 19, 2009 | D-Link AirPlus DI-524 Wireless Router
"wireless network not connected"???
Enter your IP address? If not go to http://whatismyip.com/ and enter that manually into your internet settings, on the last tab on the right of the dashboard. If the wireless adapter isn't reading the signal then you might have to reposition your router so it receives the signal.
Jun 30, 2008 | Microsoft Wireless Network Adapter Xbox...
Network Cable Unplugged
mairelina, if all was well 2 days ago then resetting the router should fix your problem. usually a small button on the back of the router.
chelliepooh, you need to check that the router's wireless function is on. connect using the ethernet and go to the config page (usually 192.168.1.1) make sure wireless is on and security is set to wpa-psk.
May 19, 2008 | NetGear WGR614 Wireless Router
Poor signal strength on wireless router? ?
k login to the w/l router and change the channels to 11>or 1 use always use these only and delete all teh temp files and delete cookies and clear history and check with antena which is straight>and reboot the router and laptop>and rate me solved if its help full
Oct 30, 2007 | Belkin (F5D6230-3) Wireless Router
Computers & Internet Logo
234 people viewed this question
David Payne
David Payne
