Follow these steps to clear the jam from the product.
Step one: Remove any loose paper
Remove any loose sheets of paper from the input tray and the output tray.
CAUTION:
Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the
print mechanism.
Do not pull jammed paper
Step two: Clear the jam from the rear of the All-in-One
Follow these steps to clear the paper jam from the rear of the product.
CAUTION:
Never pull jammed paper from the front of the product. Pulling paper
from inside the front cover can cause mechanical damage to the product.
Always access and clear
paper jams through the rear access door.
With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
Press in the tab on the rear access door to release the door.
Pull the door away from the product to remove it.
Figure 1: Remove the rear access door
To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
CAUTION:
Make
sure to remove any bits of torn paper from the rollers inside the
product. If any torn pieces of paper remain inside the product, more
jams are likely to occur.
Figure 2: Check the product for bits of torn paper
While
you have the rear access door removed, check the rollers with your
fingers. Rollers should roll freely and feel springy. If rollers are
missing or do not turn freely, buy a replacement rear access door.
Click here to order a replacement part from HP
Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION:
Carefully
remove bits of torn or jammed paper from the front of the product. If
you pull too hard on jammed paper, you might damage the print mechanism.
Make sure that you disconnect the power cord from the rear of the product.
Open the cartridge access door.
Figure 3: Open the cartridge door
Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
CAUTION:
If
the paper tears when you remove it from the rollers, check the rollers
for torn pieces of paper that might remain inside the product. If pieces
of paper remain in the product, more paper jams might occur.
Close the cartridge access door.
Reconnect the power cord to the rear of the product.
Press the Power button (
) to turn on the product.
