Question about Epson DFX-9000 Matrix Printer
Error 07 on dfx9000 printer
When i switch on my printer, i get "error 07,turn off printer" message.
i also installed a stabilizer that raised my output voltage to 230V, yet no improvement. can someone pls assist me.
I just resolve this problem by change the ROM board
ghopong@afritec.net
Posted on Sep 08, 2008
  • Epson Master
  • 691 Answers
The issue relates to the voltage. The error reports 07 as low voltage error.
The motor (+42 V) or head drive (+37 V) voltage fell below the
allowable level.
This error indicates a power output problem, or a voltage detection circuit failure.
Check and replace the following in the order below, checking
functionality at each step:
Power Unit
ROM Board
Posted on Jul 23, 2008
Lincoln sp-150 idealarc will not arc any more ground output checked ok fuses checked ok incoming power 230v ok output term for + voltage to wire on spool nopower when trigger pressed.continuity from
There is a temperature activated switch near the transformer that will turn off control voltage until the transformer cools. There is also a fuse for the control voltage. That would explain why the motor won't run. There's a possibility that the trigger switch in the handle is bad too.
Oct 15, 2014 | Welding Tools
How can output voltage be adjusted when on battery power?
1. check either it is overloaded or the batteries are weak . check battery voltage to
May 10, 2014 | APC 620VA/390W Input 230V/Output 230V...
Epson DFX9000 printer is printing blank pages
On mine it was to turn off the printer. Then while holding down the paper feed button, press the power button. Let go of the paper feed right away as soon as you hear it start up. When it's done you should get a printout with a number at the top.
OR
Still Having Epson Printer Problems Then follow Us On: Epson Printer Support
Jan 27, 2014 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Homelite LR 4300 generator only supplying 230v, even at the 120 outlets
Make certain the voltage switch is set to 120 volts, not 230 volts.
If you lost your user manual, you can download on in the link below. Just click on the "open as PDF" button and it will download t your computer. http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/electric_generator.html?p=16
Dec 20, 2017 | Electrical Supplies
Epson dfx9000 ribbon jam errors
There is a sub-board under the carriage assy. that controls all the functions. It has probably gone south.
Nov 28, 2011 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Erreur 07
Fatal Error Code 07
The motor (+42 V) or head drive (+37 V) voltage fell below the allowable level.This error indicates a power output problem, or a voltage detection circuit failure.Check and replace the following in the order below, checking functionality at each step.
1.POWER UNIT (p.136)
2.ROM BOARD (p.137)
Jul 18, 2011 | Epson DFX-9000 Matrix Printer
3-phase recty fier not output voltage 230V 10V
What is the type (input, output, power) of the rectifier.
If controllable - may be the control PCB or thyristor.
If not controllable - 10 V DC instead of 230 V DC is hardly believable.
In this case the rectifier may be OK, but the input - low.
If you have a voltmeter, check the input AC and the output DC if the output has about 200 V AC you may have shortened diode.
Jul 02, 2010 | Electric Measuring Tools & Sensors
Brand New printer status led RED, Smart Panel error "dev home"
Samsung CLP-315 Dev Home error
It appears that the Dev. Home error is very common for Samsung printers. It obviously has different reasons. In my case I solved it by stabilizing the deviation clutch. It was too unsteady and the dev. sensor recognized a fault.
The dev. clutch is situated under the right cover, which is the power supply side of the printer. To remove this cover you need to firstly remove the top cover, which is held by two screws on the front. Then uncover the right side by unscrewing one screw on the back, near the power supply inlet and unclip a couple clips on the top side of the cover. After removing it you have to find the deviation electrical clutch. Check if it is too unsteady. If it easily moves, you need to somehow stabilize it, in my case by a couple of leather straps under it, so that they press it up and make it steady: 5_19_2012_1_08_58_pm.jpg
After that simply check if you have stabilized it properly. If you have the green light must turn on after switching the device on.
NB! Be extremely careful when power is ON, because there is high voltage running. I'd suggest that you would stabilize the thing with non metallic item to keep safe. Good luck!
Apr 13, 2009 | Samsung CLP 315 Laser Printer
Epson DFX-9000 Matrix Printer Logo
231 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
